GPF when using cursor keys with a pic opened
AHCarter
Post by AHCarter »
:bug:
When opening a pic and choosing to navigate to others via the toolbar arrows, it hangs for quite some time: CTRL+ALT+DEL shows it to be Not Responding. In case it may be a setting, I submit:
Xnview INI:
[Start]
PathConvertSave=
Language=en
Version=170
UseWindowsForINI=1
X=-1
Y=-1
Width=-1
Height=-1
SavePosition=1
LaunchBrowserAtStartup=0
MaximizeXnviewAtStartup=1
ViewInFullscreen=0
AlwaysOnTop=0
OnlyOneInstance=1
OpenAll=1
ShowToolTipsInToolbar=1
FlatButtonInToolbar=1
ShowTextInToolbar=0
UseMostRecentlyUsedFiles=1
PurgeMostRecentlyUsed=0
ToolbarViewConfig=31456131
ToolbarBrowserConfig=167510030
ToolbarIndex=8
UseExtendedMenu=0
PathSlideScript=
PathAvi=
PathPalette=
PathCache=C:\Program Files\XnView
ToolbarViewConfigHigh=0
ToolbarBrowserConfigHigh=0
ToolbarName=windows
PathLoad=
PathSave=H:\From John\
PathBrowse=H:\
PathSlide=
PathScript=
PathExtract=
Only1ESC=1
[View]
BackgroundColor=8421504
MaximizeViewWhenOpen=1
OpenHexaViewIfNotPicture=0
StatusBar=1
ToolBar=1
Undo=1
ShowFilename=1
MouseNavigation=1
HideMouse=1
Fit=3
AppFitToImage=0
FileListSort=0
DoubleClickGoBrowser=0
DisableGifAnimation=0
EnableBmpAnimation=0
OnlyOneView=0
DisplayColorInformation=0
KeepZoomFactor=1
VideoLoop=1
VideoPlayBar=1
DelKeyDeleteFile=1
WheelMouseAsPreviousNext=0
UseGamma=0
Gamma=1.00
UseDPIRatio=0
ImageLoop=0
DeleteGoNext=0
CacheBehind=0
ReadAhead=0
SlideDelay=1000
SlideLoop=1
SlideDirection=0
PlayMovie=0
PlaySound=0
UseTransparency=0
HighZoomQuality=0
UseZoomStep=0
ZoomStep=10
DirKeyAsPreviousNext=0
MultipageShowAgain=1
FullHidePlayBar=0
ShowText=1
Text=<Directory><Filename>
UnitsSize=0
[File]
DirName_0=
DirName_1=
DirName_2=
DirName_3=
DirName_4=
DirName_5=
DirName_6=
DirName_7=
DirName_8=
DirName_9=
DeleteRecycleBin=1
ConfirmFileDelete=1
[Resize]
Resample=1
KeepRatio=1
[Canvas]
KeepRatio=1
Position=4
Color=0
[AutoCrop]
Tolerance=500
BackColor=16777215
[Browser]
Layout=4
DirListWidth=377
DirListHeight=108
IconListWidth=377
IconListHeight=340
X=0
Y=0
Width=808
Height=479
IconWidth=64
IconHeight=64
Viewas=1
ArrangeBy=16
ViewColumn=255
ShowDirList=1
RecognizeByExt=1
ShowHiddenFile=0
ItemsThumbnailMode=20
ItemsOtherMode=20
ShowPreview=0
FitPreviewWindow=1
ShowContent=0
ShowInAscii=0
HidePreviewScrollBar=0
PreviewColor=13172735
BackgroundColor=16777215
UseBackgroundColor=0
ThumbnailColor=0
UseThumbnailColor=0
StartupIn=2
StartupDirectory=H:\
ShowGridLines=1
UseColor=1
FullRowSelect=1
FitWindowOption=1
ShowToolTips=0
UpdateTreeViewWhenRefresh=1
DoNotStartBrowser=0
TimerForPreview=200
UseShellToOpen=0
TreeViewWidth=255
TreeViewHeight=155
ListViewWidth=541
ListViewHeight=452
PreviewWidth=0
PreviewHeight=215
ShowTextFile=1
ShowHexaView=0
ShowMovieThumbnail=1
HighQuality=0
ViewInFullscreen=0
PlayAudio=0
PlayVideo=0
SyncWithView=0
EnableAutoRefresh=1
ShowDesktop=0
UseMaxFilesize=1
MaxFilesize=5000
column0=288
column1=72
column2=120
column3=240
column4=104
column5=384
FollowLink=1
ShowIconInfo=1
FilterBy=0
[Save]
AddExtensionIfNotExist=1
GifUseTransparentIndex=0
GifTransparentIndex=0
PngUseTransparentIndex=0
PngTransparentIndex=0
JpegQuality=75
JpegProgressive=1
OptimizeHuffmanTable=1
PngCompressionLevel=6
PngInterlaced=0
FpxQuality=100
WicQuality=100
Jpeg2000Quality=100
Jpeg2000Lossless=0
IwcQuality=100
WlmFactor=1
GifInterlaced=0
IffCompress=0
PcxCompress=0
TgaCompress=0
TiffCompress=5
TiffBinaryCompress=3
SoftCompress=1
RgbCompress=1
BmpCompress=0
Os2Header=0
Hp49Header=0
Gif87aHeader=0
DpxIn10Bits=0
UseLut=0
Lut8to10Name=
DefaultFormat=jpeg
Offset=0
ChannelOrder=0
ChannelType=1
LwfCompression=0
LwfMode=0
LwfQuality=70
LwfRate=10
LwfSize=1024
LdfQuality=1
LdfAddThumbnail=1
LwfJp2Compression=0
LwfJp2Rate=10
LwfJp2Size=4096
PpmAscii=0
EcwTargetRatio=20
JpegKeepEXIF=1
JpegKeepIPTC=1
Jpeg2000Mode=2
Jpeg2000Ratio=10
Jpeg2000FileSize=100
LdfjpmQuality=8
LdfjpmBitonalCoder=2
LdfjpmBackFactors=1
LdfjpmForeFactors=1
[Load]
PcdBase=2
GrobBpp=0
DjVuMaxDpi=0
PostscriptDpi=72
PostscriptPageSize=0
IgnoreError=0
YuvWidth=720
YuvHeight=576
YuvOffset=0
Width=256
Height=256
Offset=0
ChannelOrder=0
ChannelType=1
Preview=1
UseLut=0
Lut10to8Name=
PngComposeWithTransparency=0
PngComposeWithAlpha=0
CRWHighResolution=0
[Slide]
UseTimer=1
Timer=0
Loop=1
Full=1
Center=1
Random=1
FitToWindow=1
NoTitle=1
NoError=0
HideMouse=0
ShowFilename=1
SortOder=0
BackgroundColor=0
SLDRelativePathname=0
ShowText=1
FontBold=0
FontItalic=0
FontHeight=-13
TextColor=16777215
IsTransparent=1
FontName=Courier
Position=0
[Rename]
Start=10
Step=1
Template=!<Filename No Ext>
Extension=jpg
UseTemplate=1
UseExtension=1
CaseFlag=0
[Html]
TableColumns=3
TableRows=3
TableBorder=2
ThumbWidth=100
ThumbHeight=100
Format=0
InterlacedGif=1
ProgressiveJpeg=1
QualityJpeg=100
UseOriginalIfSmaller=1
CopySourceFilename=1
LaunchWebBrowser=1
Display=1
Sort=0
OutputDirectory=L:\Wanasa\Gallery\
ShowInfos=1
Text=<Filename>||<Width> x <Height>||<Size KB> KB
[Print]
Option=0
CenterOnPage=1
AllPages=0
Units=1
ShowInfo=0
Orientation=0
KeepAspectRatio=1
Width=7.74
Height=9.75
LeftMargin=0.20
TopMargin=0.20
XScale=10.00
YScale=0.00
Text=<Filename>
[ContactSheet]
Width=800
Height=600
Columns=3
Rows=3
MarginWidth=8
MarginHeight=8
SpacingWidth=2
SpacingHeight=2
FontName=Times New Roman
FontHeight=-16
FontBold=0
FontItalic=0
Flags=134
HeadNote=The End Collection for Mikey
FootNote=
BackgroundColor=16777088
TextBackgroundColor=16777215
TextColor=0
ThumbnailBackgroundColor=16777215
[Capture]
Delay=1
Area=0
Method=0
HideXnView=1
HideCursor=1
Multiple=0
HotKey=10
ClientArea=0
IncludeCursor=0
FormatName=jpeg
Directory=
SaveIntoFile=0
[Cache]
IsActive=1
Compression=1
MaxDir=0
[Scan]
Directory=
FileName=Scan
FormatName=jpeg
StartIndex=0
Page=3
[MultFile]
[Process]
AutoView=1
Deinterlace=0
LastValue_0=84
LastValue_1=0
LastValue_2=100
LastValue_3=-255
LastValue_4=-255
LastValue_5=3
LastValue_6=-255
LastValue_7=3
LastValue_8=-255
LastValue_9=-255
LastValue_10=99
LastValue_11=99
LastValue_12=0
LastValue_13=-255
LastValue_14=-255
LastValue_15=-255
LastValue_16=99
LastValue_17=-255
LastValue_18=-255
LastValue_19=0
LastValue_20=0
LastValue_21=0
LastValue_22=179
LastValue_23=357
LastValue_24=-255
LastValue_25=-255
[Install]
ViewAsName=0
[Convert]
HideError=0
DeleteOriginal=0
Overwrite=3
KeepOriginalDate=0
DefaultFormat=jpeg
[FileSelector]
IncludeSubDirectories=0
[FileTypes]
jpeg=1
tga=0
tiff=0
pict=0
bmp=1
os2=1
iff=0
lbm=0
png=0
mng=0
gif=1
pcx=0
dcx=0
pbm=0
pgm=0
ppm=0
pnm=0
p7=0
psd=0
pdd=0
ico=1
cur=1
clp=0
dib=0
ani=1
tdi=0
soft=0
sgi=0
ras=0
miff=0
xbm=0
xpm=0
pcd=0
psion3=0
psion5=0
palm=0
psp=0
pspp=0
pspt=0
tub=0
pfr=0
jbf=0
pmsk=0
2bp=0
stm=0
fsy=0
cpt=0
xif=0
ce=0
icb=0
vda=0
g3n=0
wmf=0
emf=1
icl=0
ps=0
epi=0
pdf=0
ai=0
pdx=0
eps=1
vista=0
alias=0
rla=0
rle=0
pxr=0
taac=0
sct=0
cin=0
dpx=0
vpb=0
hru=0
gem=0
dkb=0
qrt=0
cloe=0
vivid=0
mtv=0
ray=0
cp8=0
ish=0
icon=0
jif=0
pegs=0
bum=0
cdr=0
cpat=0
cbmf=0
cmx=0
fbm=0
pm=0
sfw=0
pwp=0
cam=0
j6i=0
kdc=0
kqp=0
tim=0
pmp=0
sj1=0
cmt=0
k25=0
qtif=0
synu=0
xcf=0
gbr=0
gpat=0
gicon=0
iim=0
esm=0
grob=0
ti=0
ngg=0
nol=0
nlm=0
otb=0
fits=0
arn=0
vicar=0
pds=0
stx=0
viff=0
xim=0
fit=0
degas=0
neo=0
zzrough=0
dali=0
ce1=0
stad=0
gfaray=0
spu=0
spc=0
sps=0
rix=0
cmu=0
xwd=0
pic=0
ilab=0
msp=0
crg=0
art=0
aurora=0
qdv=0
tdim=0
eidi=0
biorad=0
bob=0
face=0
wpg=0
anv=0
arf=0
prisms=0
lff=0
pixi=0
zbr=0
zmf=0
kps=0
fli=0
ioca=0
cals=0
kfx=0
imt=0
ncr=0
fxs=0
bfx=0
ingr=0
eyes=0
mgr=0
atk=0
map=0
fpg=0
fmap=0
ffpg=0
nitf=0
rad=0
vit=0
adex=0
lda=0
sfax=0
img=0
pig=0
hsi=0
smp=0
nist=0
im5=0
ssi=0
lwi=0
vort=0
aces=0
acc=0
gpb=0
skn=0
vif=0
abmp=0
cat=0
mrf=0
prf=0
teal=0
dcpy=0
cadc=0
ppp=0
god=0
abs=0
npm=0
stw=0
car=0
esmp=0
sir=0
vi=0
ct=0
imgt=0
jps=0
2d=0
vob=0
iss=0
pgc=0
til=0
pxa=0
lif=0
mdl=0
gaf=0
iimg=0
fi=0
lvp=0
crw=0
upi=0
sdg=0
b16=0
xar=0
bif=0
pan=0
bga=0
mag=0
tnl=0
ecc=0
psf=0
oil=0
winm=0
mfrm=0
ipg=0
pabx=0
kskn=0
prc=0
wbc=0
hpi=0
hta=0
apx=0
afx=0
pd=0
fre=0
b3d=0
pp4=0
pp5=0
fsh=0
wad=0
bms=0
tile=0
iris=0
bmc=0
sdt=0
frm=0
skp=0
ttf=0
cft=0
eif=0
mtx=0
xp0=0
dcmp=0
cel=0
wal=0
m8=0
ssp=0
btn=0
info=0
*=0
fff=0
pps=0
ppt=0
pzp=0
aphp=0
upst=0
upe4=0
icd=0
pgf=0
gm=0
pixp=0
bld=0
411=0
rsb=0
wrl=0
pcl=0
cut=0
dbw=0
acorn=0
avs=0
aim=0
mac=0
tiny=0
doodle=0
artdir=0
zxscr=0
zxsna=0
zxhob=0
msx2=0
koa=0
gg=0
a64=0
cipt=0
rpm=0
p64=0
sar=0
drz=0
vid=0
ocp=0
cdu=0
pi=0
cism=0
rp=0
mil=0
pmg=0
hed=0
cish=0
ciph=0
geo=0
ami=0
hir=0
dd=0
jj=0
prx=0
bfli=0
cpc=0
hr=0
hdru=0
q0=0
brk=0
oaz=0
can=0
jtf=0
sci=0
att=0
rfax=0
fax=0
wbmp=0
rlc2=0
c4=0
tg4=0
pfs=0
dicom=0
pzl=0
hrz=0
lcel=0
hf=0
star=0
pseg=0
cvp=0
ript=0
ofx=0
arcib=0
spot=0
mklg=0
mkcf=0
epa=0
mbig=0
pbt=0
byusir=0
cncd=0
cnct=0
skf=0
st4=0
aip=0
lss=0
ohir=0
otap=0
uyvyi=0
uyvy=0
yuv411=0
yuv422=0
yuv444=0
raw=0
avi=0
mpeg=0
mov=0
exe=1
mjpg=0
epsp=0
dds=0
tim2=0
icns=0
xyz=0
tjp=0
fmag=0
bias=0
cpa=0
tsk=0
nef=0
trup=0
jp2=0
jpc=0
pspf=0
pspb=0
pspm=0
ace=0
bdr=0
efx=0
adt=0
f96=0
bmg=0
d3d=0
jig2=0
jig=0
ncy=0
syj=0
v=0
fx3=0
hdri=0
psa=0
gun=0
fpt=0
dol=0
fp2=0
nsr=0
gig=0
gih=0
mh=0
gmf=0
wfx=0
uni=0
vfx=0
fcx=0
ftf=0
dsi=0
kntr=0
dta=0
pcp=0
bsg=0
wzl=0
sst=0
bpr=0
mph=0
g16=0
[OpenWith]
OpenWith_0=C:\My Programs\EditPadLite\EditPad.exe
OpenWith_1=C:\Program Files\Windows Media Player\mplayer2.exe
OpenWith_2=C:\WINDOWS\PBRUSH.EXE
OpenWith_3=C:\WINDOWS\Explorer.exe
[Text]
FontBold=1
FontItalic=0
FontHeight=-13
TextColor=255
IsTransparent=1
FontName=Courier
String=first
[Movie]
[Search]
Pattern=silbury*.*
Directory=H:\
Word=
Flags=1
FileSize=0
FileSizeFlags=0
FormatName=
[Fullscreen]
FontBold=0
FontItalic=0
FontHeight=-13
TextColor=16777215
BackgroundColor=0
IsTransparent=1
FontName=Courier
Position=0
[Pan]
Orientation=0
HOrientation=1
VOrientation=1
Center=0
[JpegTrnfm]
Trim=1
KeepDate=0
System Info:
Machine::                     LCARS 20040517
User::                        WORKGROUP\A.H. Carter
Operating System::            Windows 98 Version 4.10 build 1034.2222  A
Processor::                   Cyrix 6x86MX (MMX), 250 MHz
Front Side Bus Speed::        Unknown
Date and Time::               07/29/2004 01:03:23
Cache::
RAM::                         379 MB (397,881,344 bytes)
MACHINE.exe version::         2.21.334.524
database location::           C:\MY PROGRAMS\MACHINE\machine.txt
Winsock version::             Microsoft wsock32.dll, ver2.2, 32bit of Apr 22 1999, at 20:29:32.
IE Version::                  6.0.2800.1106
Game::                        Age of Empires II: The Conquerors Expansion
Build::
Bug Title::
Bug Description::
Repro::
Result::
Expected::
Comments::
Severity::                    1
Test Results::
Number of Displays::          1
Passed stability test::       no
Passed visual quality test::  no
Passed custom test 1::        no
Passed custom test 2::        no
Display Adapter 1::           no
Display Adapter 2::           no
Simple Log Information DX::   no
Simple Log Information Caps:: no
Raid Environment::            LCARS 20040517:Cyrix 6x86MX (MMX), 250 MHz:Windows 98 Version 4.10 build 1034.2222  A :216.79.217.57  :379 MB (397,881,344 bytes):Microsoft wsock32.dll, ver2.2, 32bit of Apr 22 1999, at 20:29:32.:SiS 530 (dd530_32.dll 4.11.1.1030)
Drive C free space::          5,363,793,920
Drive C total space::         8,578,609,152
Drive C cluster size::        4,096 bytes
Drive C file system::         FAT32
Drive C description::         GENERIC IDE  DISK TYPE47
Drive C revision::
Drive D free space::          8,418,988,032
Drive D total space::         8,578,613,248
Drive D cluster size::        4,096 bytes
Drive D file system::         FAT32
Drive D description::         GENERIC IDE  DISK TYPE47
Drive D revision::
Drive E free space::          6,998,343,680
Drive E total space::         8,578,613,248
Drive E cluster size::        4,096 bytes
Drive E file system::         FAT32
Drive E description::         GENERIC IDE  DISK TYPE47
Drive E revision::
Drive F free space::          6,706,741,248
Drive F total space::         8,578,609,152
Drive F cluster size::        4,096 bytes
Drive F file system::         FAT32
Drive F description::         GENERIC IDE  DISK TYPE47
Drive F revision::
Drive G free space::          7,729,537,024
Drive G total space::         8,578,609,152
Drive G cluster size::        4,096 bytes
Drive G file system::         FAT32
Drive G description::         GENERIC IDE  DISK TYPE47
Drive G revision::
Drive H free space::          7,090,626,560
Drive H total space::         8,578,609,152
Drive H cluster size::        4,096 bytes
Drive H file system::         FAT32
Drive H description::         GENERIC IDE  DISK TYPE47
Drive H revision::
Drive I free space::          7,998,267,392
Drive I total space::         8,578,613,248
Drive I cluster size::        4,096 bytes
Drive I file system::         FAT32
Drive I description::         GENERIC IDE  DISK TYPE47
Drive I revision::
Drive J free space::          6,074,798,080
Drive J total space::         8,578,613,248
Drive J cluster size::        4,096 bytes
Drive J file system::         FAT32
Drive J description::         GENERIC IDE  DISK TYPE47
Drive J revision::
Drive K free space::          7,428,116,480
Drive K total space::         8,578,613,248
Drive K cluster size::        4,096 bytes
Drive K file system::         FAT32
Drive K description::         GENERIC IDE  DISK TYPE47
Drive K revision::
Drive L free space::          7,870,222,336
Drive L total space::         8,578,613,248
Drive L cluster size::        4,096 bytes
Drive L file system::         FAT32
Drive L description::         GENERIC IDE  DISK TYPE47
Drive L revision::
Drive M free space::          6,441,750,528
Drive M total space::         8,578,613,248
Drive M cluster size::        4,096 bytes
Drive M file system::         FAT32
Drive M description::         GENERIC IDE  DISK TYPE47
Drive M revision::
Drive N free space::          8,171,311,104
Drive N total space::         8,578,613,248
Drive N cluster size::        4,096 bytes
Drive N file system::         FAT32
Drive N description::         GENERIC IDE  DISK TYPE47
Drive N revision::
Drive O free space::          8,578,605,056
Drive O total space::         8,578,613,248
Drive O cluster size::        4,096 bytes
Drive O file system::         FAT32
Drive O description::         GENERIC IDE  DISK TYPE47
Drive O revision::
Drive P free space::          8,577,658,880
Drive P total space::         8,578,613,248
Drive P cluster size::        4,096 bytes
Drive P file system::         FAT32
Drive P description::         GENERIC IDE  DISK TYPE47
Drive P revision::
Drive Q free space::
Drive Q total space::
Drive Q cluster size::
Drive Q file system::         CDROM
Drive Q description::         LITEON CD-ROM LTN323
Drive Q revision::            DQ15
   --- Net 0 --------------------------------------------------------
   Net 0 Name::               PPP Adapter.
   Net 0 IPAddress::          216.79.217.57
   Net 0 Subnet Mask::        255.255.255.0
   Net 0 Physical Address::   44-45-53-54-00-00
   --- Sound 0 ------------------------------------------------------
   Sound 0 Name::             ESS PCI Solo-1 DirectSound Driver
   Sound 0 Driver::           ESSOLO.VXD
   Sound 0 Version::          4.5.0.1087
   Sound 0 Mode::             Native
   --- DPApp 0 ------------------------------------------------------
   DPApp 0 Name::             Age of Empires II
   DPApp 0 Directory::        C:\Program Files\Microsoft Games\Age of Empires II
   DPApp 0 File Name::        Empires2.ICD
   --- DPApp 1 ------------------------------------------------------
   DPApp 1 Name::             Age of Empires II - The Conquerors Expansion
   DPApp 1 Directory::        C:\Program Files\Microsoft Games\Age of Empires II\Age2_X1
   DPApp 1 File Name::        \age2_x1.icd
   --- Display 0 ------------------------------------------------------
   Display 0 Name::           SiS 530
   Display 0 OEM::            SiS
   Display 0 DD Driver::      dd530_32.dll
   Display 0 DD Version::     4.11.1.1030
   Display 0 DD Date::        4/03/1999 11:41a
   Display 0 DD Size::        125,440 bytes
   Display 0 DD Attrib::      Final Release
   Display 0 GDI Driver::     sis530v.drv
   Display 0 GDI Version::    4.11.1.1030
   Display 0 GDI Date::       4/03/1999 11:40a
   Display 0 GDI Size::       81,120 bytes
   Display 0 GDI Attrib::     Final Release, Private Build
   Display 0 PNPID::          PCI\VEN_1039&DEV_6306&SUBSYS_63061039&REV_A2\001000
   Display 0 VRAM::           4 MB
   Display 0 VRAM_VS::        2,906,625 (2,906,625)
   Display 0 VRAM_SS::        2,906,625 (2,906,625)
   Display 0 VRAM_AS::        0 (0)
   Display 0 VRAM_VT::        2,906,625 (2,906,625)
   Display 0 VRAM_ST::        2,906,625 (2,906,625)
   Display 0 VRAM_AT::        0 (0)
   DirectX 0 drv/sys::        DX6/DX7
   Display 0 DX6 DI drv::     dd530_32.dll
   Display 0 DX6 DI desc::    SiS 530
   Display 0 DX6 DI drv ver:: 4.11.1.1030
   Display 0 DX6 DI vendor::  0x00001039
   Display 0 DX6 DI dev id::  0x00006306
   Display 0 DX6 DI subsys::  0x63061039
   Display 0 DX6 DI rev::     0x000000A2
   Display 0 DX6 DI guid::    {D7B71ED9-2046-11CF-8F77-074306C2C935}
   Display 0 (DX3+) DDCAPS_3D::                              Yes
   Display 0 (DX3+) DDCAPS_ALIGNBOUNDARYDEST::               No
   Display 0 (DX3+) DDCAPS_ALIGNSIZEDEST::                   No
   Display 0 (DX3+) DDCAPS_ALIGNBOUNDARYSRC::                No
   Display 0 (DX3+) DDCAPS_ALIGNSIZESRC::                    No
   Display 0 (DX3+) DDCAPS_ALIGNSTRIDE::                     No
   Display 0 (DX3+) DDCAPS_BLT::                             Yes
   Display 0 (DX3+) DDCAPS_BLTQUEUE::                        Yes
   Display 0 (DX3+) DDCAPS_BLTFOURCC::                       No
   Display 0 (DX3+) DDCAPS_BLTSTRETCH::                      No
   Display 0 (DX3+) DDCAPS_GDI::                             Yes
   Display 0 (DX3+) DDCAPS_OVERLAY::                         Yes
   Display 0 (DX3+) DDCAPS_OVERLAYCANTCLIP::                 Yes
   Display 0 (DX3+) DDCAPS_OVERLAYFOURCC::                   Yes
   Display 0 (DX3+) DDCAPS_OVERLAYSTRETCH::                  Yes
   Display 0 (DX3+) DDCAPS_PALETTE::                         Yes
   Display 0 (DX3+) DDCAPS_PALETTEVSYNC::                    No
   Display 0 (DX3+) DDCAPS_READSCANLINE::                    Yes
   Display 0 (DX3+) DDCAPS_STEREOVIEW::                      No
   Display 0 (DX3+) DDCAPS_VBI::                             No
   Display 0 (DX3+) DDCAPS_ZBLTS::                           Yes
   Display 0 (DX3+) DDCAPS_ZOVERLAYS::                       Yes
   Display 0 (DX3+) DDCAPS_COLORKEY::                        Yes
   Display 0 (DX3+) DDCAPS_ALPHA::                           Yes
   Display 0 (DX3+) DDCAPS_COLORKEYHWASSIST::                No
   Display 0 (DX3+) DDCAPS_NOHARDWARE::                      No
   Display 0 (DX3+) DDCAPS_BLTCOLORFILL::                    Yes
   Display 0 (DX3+) DDCAPS_BANKSWITCHED::                    No
   Display 0 (DX3+) DDCAPS_BLTDEPTHFILL::                    Yes
   Display 0 (DX3+) DDCAPS_CANCLIP::                         No
   Display 0 (DX3+) DDCAPS_CANCLIPSTRETCHED::                No
   Display 0 (DX3+) DDCAPS_CANBLTSYSMEM::                    No
   Display 0 (DX3+) DDCAPS2_CERTIFIED::                      Yes
   Display 0 (DX3+) DDCAPS2_NO2DDURING3DSCENE::              No
   Display 0 (DX5+) DDCAPS2_VIDEOPORT::                      No
   Display 0 (DX5+) DDCAPS2_AUTOFLIPOVERLAY::                No
   Display 0 (DX5+) DDCAPS2_CANBOBINTERLEAVED::              No
   Display 0 (DX5+) DDCAPS2_CANBOBNONINTERLEAVED::           No
   Display 0 (DX5+) DDCAPS2_COLORCONTROLOVERLAY::            No
   Display 0 (DX5+) DDCAPS2_COLORCONTROLPRIMARY::            No
   Display 0 (DX5+) DDCAPS2_CANDROPZ16BIT::                  No
   Display 0 (DX5+) DDCAPS2_NONLOCALVIDMEM::                 Yes
   Display 0 (DX5+) DDCAPS2_NONLOCALVIDMEMCAPS::             Yes
   Display 0 (DX5+) DDCAPS2_NOPAGELOCKREQUIRED::             No
   Display 0 (DX5+) DDCAPS2_WIDESURFACES::                   Yes
   Display 0 (DX5+) DDCAPS2_CANFLIPODDEVEN::                 No
   Display 0 (DX5+) DDCAPS2_CANBOBHARDWARE::                 No
   Display 0 (DX6+) DDCAPS2_COPYFOURCC::                     Yes
   Display 0 (DX6+) DDCAPS2_PRIMARYGAMMA::                   Yes
   Display 0 (DX6+) DDCAPS2_CANRENDERWINDOWED::              Yes
   Display 0 (DX6+) DDCAPS2_CANCALIBRATEGAMMA::              No
   Display 0 (DX6+) DDCAPS2_FLIPINTERVAL::                   No
   Display 0 (DX6+) DDCAPS2_FLIPNOVSYNC::                    No
   Display 0 (DX7+) DDCAPS2_CANMANAGETEXTURE::               No
   Display 0 (DX7+) DDCAPS2_STEREO::                         No
   Display 0 (DX7+) DDCAPS2_TEXMANINNONLOCALVIDMEM::         No
   Display 0 (DX3+) Display Mode 1::                         640x480x8
   Display 0 (DX3+) Display Mode 2::                         640x480x16
   Display 0 (DX3+) Display Mode 3::                         800x600x8
   Display 0 (DX3+) Display Mode 4::                         800x600x16
   Display 0 (DX3+) Display Mode 5::                         1024x768x8
   Display 0 (DX3+) Display Mode 6::                         1024x768x16
   Display 0 (DX3+) Display Mode 7::                         1024x768x32
   Display 0 (DX3+) Display Mode 8::                         640x400x8
   Display 0 (DX3+) Display Mode 9::                         640x400x16
   Display 0 (DX3+) Display Mode 10::                        320x200x8
   Display 0 (DX3+) Display Mode 11::                        320x200x16
   Display 0 (DX3+) Display Mode 12::                        320x240x8
   Display 0 (DX3+) Display Mode 13::                        320x240x16
   Display 0 (DX3+) Display Mode 14::                        400x300x8
   Display 0 (DX3+) Display Mode 15::                        400x300x16
   Display 0 (DX3+) Display Mode 16::                        512x384x8
   Display 0 (DX3+) Display Mode 17::                        512x384x16
   Display 0 (DX3+) D3DDEVCAPS_FLOATTLVERTEX::               Yes
   Display 0 (DX3+) D3DDEVCAPS_SORTINCREASINGZ::             No
   Display 0 (DX3+) D3DDEVCAPS_SORTDECREASINGZ::             No
   Display 0 (DX3+) D3DDEVCAPS_SORTEXACT::                   Yes
   Display 0 (DX3+) D3DDEVCAPS_EXECUTESYSTEMMEMORY::         Yes
   Display 0 (DX3+) D3DDEVCAPS_EXECUTEVIDEOMEMORY::          No
   Display 0 (DX3+) D3DDEVCAPS_TLVERTEXSYSTEMMEMORY::        Yes
   Display 0 (DX3+) D3DDEVCAPS_TLVERTEXVIDEOMEMORY::         No
   Display 0 (DX3+) D3DDEVCAPS_TEXTURESYSTEMMEMORY::         No
   Display 0 (DX3+) D3DDEVCAPS_TEXTUREVIDEOMEMORY::          Yes
   Display 0 (DX5+) D3DDEVCAPS_DRAWPRIMTLVERTEX::            Yes
   Display 0 (DX5+) D3DDEVCAPS_CANRENDERAFTERFLIP::          No
   Display 0 (DX5+) D3DDEVCAPS_TEXTURENONLOCALVIDMEM::       Yes
   Display 0 (DX6+) D3DDEVCAPS_DRAWPRIMITIVES2::             Yes
   Display 0 (DX6+) D3DDEVCAPS_SEPARATETEXTUREMEMORIES::     No
   Display 0 (DX7+) D3DDEVCAPS_CANBLTSYSTONONLOCAL::         No
   Display 0 (DX7+) D3DDEVCAPS_HWTRANSFORMANDLIGHT::         No
   Display 0 (DX6+) D3DFVFCAPS_DONOTSTRIPELEMENTS::          No
   Display 0 (DX6+) D3DFVFCAPS_TEXCOORDCOUNTMASK::           Yes
   Display 0 (DX3+) D3DPTFILTERCAPS_LINEAR (Bilinear filtering):: Yes
   Display 0 (DX3+) D3DPTFILTERCAPS_LINEARMIPLINEAR (Trilinear filtering):: Yes
   Display 0 (DX3+) Texture Format 1::                       15-bit 555 RGB
   Display 0 (DX3+) Texture Format 2::                       16-bit 565 RGB
   Display 0 (DX3+) Texture Format 3::                       24-bit 888 RGB
   Display 0 (DX3+) Texture Format 4::                       0-bit 000 RGB
   Display 0 (DX3+) Texture Format 5::                       32-bit 8888 RGB ALPHAPIXELS
   Display 0 (DX3+) Texture Format 6::                       16-bit 5551 RGB ALPHAPIXELS
   Display 0 (DX3+) Texture Format 7::                       16-bit 4444 RGB ALPHAPIXELS
   --- Net Card 0 -----------------------------------------------------
   Net Card 0::               PPP Adapter.
   --- DirectX Files -------------------------------------------------------
   ddraw.dll::       4.09.0000.0900   Final Release   12/12/2002 12:14a       358,400 bytes
   ddraw16.dll::     4.07.0000.0700   Final Release    9/09/1999  7:00a        28,496 bytes
   ddhelp.exe::      4.09.0000.0900   Final Release   12/12/2002 12:14a        32,768 bytes
   dsound.dll::      4.09.0000.0900   Final Release   12/12/2002 12:14a       457,728 bytes
   dsound.vxd::      4.09.0000.0900 Final Release, Private Build   12/12/2002 12:14a        47,664 bytes
   dinput.dll::      4.08.0001.0901   Final Release   10/30/2001  8:10a       172,032 bytes
   dinput.vxd::      4.08.0001.0881   Final Release   10/30/2001  8:10a        10,874 bytes
   vjoyd.vxd::       4.08.0001.0881   Final Release   10/30/2001  8:10a        33,882 bytes
   msanalog.vxd::    4.08.0001.0881   Final Release   10/30/2001  8:10a        12,745 bytes
   joy.cpl::         4.08.0001.0881 Final Release, Private Build   10/30/2001  8:10a       442,368 bytes
   dplayx.dll::      4.09.0000.0900   Final Release   12/12/2002 12:14a       229,376 bytes
   dpmodemx.dll::    4.09.0000.0900   Final Release   12/12/2002 12:14a        36,864 bytes
   dpwsockx.dll::    4.09.0000.0900   Final Release   12/12/2002 12:14a        65,536 bytes
   dplaysvr.exe::    4.09.0000.0900   Final Release   12/12/2002 12:14a        40,960 bytes
   d3drm.dll::       4.06.0002.0436   Final Release    4/23/1999 10:22p       446,464 bytes
   d3dxof.dll::      4.06.0002.0436   Final Release    4/23/1999 10:22p       118,784 bytes
   d3dpmesh.dll::    4.06.0002.0436   Final Release    4/23/1999 10:22p       102,400 bytes
   d3dim.dll::       4.07.0000.0700   Final Release    9/09/1999  7:00a       625,690 bytes
Sincerely,
A.H. Carter
d(-_-)b
OS:Win 98 SE
Processor:Cyrix 6x86MX (MMX), 250 MHz
Xnview Ver: 1.74
RAM: 380MB
Re: BUG: Found a bug when using the arrows with a pic opened
AHCarter wrote::bug:
Which format do you have in this folder?
AHCarter
Post by AHCarter »
I think it happens when the "Arrange by" is in "Type" when in numeric it seems to work. Foe a while I was thinking that it may have something to do with file sizes (KB/MB) but I belive it is the "Arrange by" where it seems to hang.
Sincerely,
A.H. Carter
d(-_-)b
OS:Win 98 SE
Xnview Ver: 1.74
RAM: 380MB
AHCarter wrote:I think it happens when the "Arrange by" is in "Type" when in numeric it seems to work. Foe a while I was thinking that it may have something to do with file sizes (KB/MB) but I belive it is the "Arrange by" where it seems to hang.
Yes :bugconfirmed: with Arrange by type!
