Open "Next" file after deleting any file in folder
zridling
Post by zridling »
Here's the situation:
(1) I'm in thumbnail mode in the XnView browser;
(2) I select a file in the middle of the folder list;
(3) Delete the file.
(4) RESULT: I'm kicked back to the first file in the folder.
What I would like to be able to do is to open any file in the folder, delete it, and have the "next" file in the folder open. Is there a way to do this, or can I file this as an enhancement suggestion for a future version?
- Zaine Ridling
The Great Software List
Re: Open "Next" file after deleting any file in fo
zridling wrote:Here's the situation:
Strange, i can't reproduce the problem. Which sort option do you have?
Regards. Pierre.
Post by Guest »
I'm sorting the thumbnails/files by name; and I have "Loop on the file list" and "Go to next image when deleting current" both checked in Options.
Post by Guest »
Even when I uncheck the "Loop on the file list" option, and leave the "Go to next image when deleting current" checked, it still kicks me back to the first image if I open one file in the middle of the list and just delete it. I'm not cycling (using the space bar) to the next image, just deleting the first one I open.
crazytb
Confirmed at Linux
Post by crazytb »
Confimed! At XnView 1.50 for Linux this happens. I don't know about Windows version, and I don't know which version our guest is using.
BTW, I cannot find "Loop on the file list" and "Go to next image when deleting current" options at Linux box.
I've tried to reproduce the problem with XnView 1.65 on Windows 98 FE, but did not succeed. Which XnView version do you use? Which OS?
Perhaps a special option in XnView is set which influences and causes this problem. Could you please send your .ini file to Pierre and/or me?
jingles
Same thing.. (and more)
Post by jingles »
Hey!
I encountered the same issues not just when deleting files, but also when changing from "normal"-mode to browser-mode (by clicking enter)..
- the cursor jumps always to the first element in the directory
- no element is selected!
- but the quick-view in browser-mode shows the right-picture
My XnView is the german-version 1.66
If you need more informations just say something..
Best regards, jingles
Anonymous wrote:Even when I uncheck the "Loop on the file list" option, and leave the "Go to next image when deleting current" checked, it still kicks me back to the first image if I open one file in the middle of the list and just delete it. I'm not cycling (using the space bar) to the next image, just deleting the first one I open.
Sorry but on my win2k, all is ok. I don't understand.
Iron
It happens to me too
Post by Iron »
The same thing happens to me here.... XnView 1.66 on Win XP
You double click a picture and go to the view menu but when you come back simply no picture is select! So if you press any arrow key, you´ll go to the first, second... picture.
It happens the same way if you resize a picture, delete other picture, etc...
jingles
Found something out..
Post by jingles »
Hey!
Since there is no solution yet, I probably made a useful discovery:
I browsed my DigiCam with XnView and pressed :ENTER: to watch one image more closer in Fullscreen-Mode. I pressed :ENTER: again to change to Browser-Mode and.. It works! The right thumbnail was selected..
And here's what seems to happen: When I browsed my cam, not all of the thumbnails were already loaded.. Switching between browser and fullscreen seems to work..
Moments later all thumbnails were generated and imagine what happened!
The cursor jumps to the first thumbnail .. It seems that after XnView generated all of the thumbnails, it performs a Reload that causes this bug.
I hope this will be useful to solve the problem..
regards, jingles
Post by Guest »
I'm using WinXP-SP1, and it happens. However, in XnView Deluxe 2, it's repaired.
