Batch editing - order of commands unchangeable?
henrik2000
Hi. When batch editing, i collect several commands like "file size" and "sharpen". But i cannot change the order of the collected commands? I have to remove the commands and add them again in my desired order? (For example, you wouldn't want sharpening before resizing.) Thanks!
Anika
Dreamer
Re: Batch editing - order of commands unchangeable?
Ok, i'll add this feature.henrik2000 wrote:Hi. When batch editing, i collect several commands like "file size" and "sharpen". But i cannot change the order of the collected commands? I have to remove the commands and add them again in my desired order? (For example, you wouldn't want sharpening before resizing.) Thanks!
