Thumbnail compare when copying or moving
sullysnet
Post by sullysnet »
Thumbnail compare when copying or moving: Has this been added in at all does anyone know ????? It is something in ACDsee that I love alot other then that I would be using XnView for sure. MOre stable and just a pleasure to use.
If it is not in the app is there a place that I can request it be added in ???
thanks alot
Re: thumbnail compare when copying or moving .....
sullysnet wrote:has this been added in at all does anyone know ????? It is something in ACDsee that I love alot other then that I would be using XnView for sure. MOre stable and just a pleasure to use.
In my TODO list :-)
sullysnet
Post by sullysnet »
OH MAN you are the best Pierre I really want to move to your app so bad I can taste it. I am just waiting for this part. Please post back and let me know if it is added :)
I know you show what you updated in the app but not sure how this will be worded :) so I don't want to miss it
thanks
Thumbnail compare when copying or moving .....
This does not mean anything to me, could someone please explain?
Lostclown
Post by Lostclown »
When a copy or move file operation is about to overwrite a file this feature will display a thumb of both images and prompting if it should overwrite.
So simple when you know :)
Lostclown wrote:[...]
Thank you, Lostclown, for the explanation, now it is clear to me (and other users). Before overwriting a file, it's really helpful to give the user some extra info or even a picture at hand so that he/she can decide. Apart from the preview other image info like image width/height could be also helpful.
sullysnet
Post by sullysnet »
Yes this sounds great, ACDsee does size and preview thumbnail but more info would be cool. I guess ones that are important :)
I know that Pierre will make it a better feature then ACDsee or Pierre and his team. Not sure who is doing the development.
Sorry I didn't give full details of what I was looking for but I figured that the developer would understand what I was talking about.
Can't wait for this feature so I can FINALLY DUMP ACDsee :P :P :P
sullysnet
Post by sullysnet »
Pierre is this in this new 1.74 RC1 version ???? I didn't see it in the list but it could be called something else.
thanks alot for the info and the hard work
Sully
sullysnet wrote:Pierre is this in this new 1.74 RC1 version ???? I didn't see it in the list but it could be called something else.
Not in this release, sorry!
sullysnet
Post by sullysnet »
OH MAN :( I know it must be alot to add. If and when you add it what do you think you will note the feature as ???? So I don't have to ask. Not sure if there is a technical name for this or not :)
thanks again and great work
sullysnet wrote:OH MAN :( I know it must be alot to add. If and when you add it what do you think you will note the feature as ???? So I don't have to ask. Not sure if there is a technical name for this or not :)
Okay, perhaps i could add this feature in the current release....
sullysnet
Post by sullysnet »
OK you are the coolest :) thanks alot
testing it out now :)
sullysnet wrote:OK you are the coolest :) thanks alot
You have it in 1.74 RC3
Lostclown
Post by Lostclown »
xnview wrote:You have it in 1.74 RC3
The preview thumbnails did not show up for me when using drag-and-drop to copy or move files in RC3.
It just shows a Confirm File Replace dialog as in previous versions.
What am I doing wrong here :??
Lostclown
Oh yes, i've added it only in the "Copy to" or "Move to" command.
