usually XnView shows my jpg-sequences quite fluendly and at something 25fps. Just enter an image of it hold Space.. Cool thang. But If I got some applycations open XnView starts to stutter, stops playing back.. I close it, open it um again ... now it shows more frames fluend until it stops again.
Whould be great if this whould always work.
viewing jpg image sequences
Re: viewing jpg image sequences
You means with quick slide show?eweryboooody wrote:usually XnView shows my jpg-sequences quite fluendly and at something 25fps. Just enter an image of it hold Space.. Cool thang. But If I got some applycations open XnView starts to stutter, stops playing back.. I close it, open it um again ... now it shows more frames fluend until it stops again.
eweryboooody
AndyWelder
eweryboooody
No this is a completely other problem. But I know this nasty one too!!
In my case xnview responses correctly from the first image on but if you hold "Next Image" it begins to stutter and stop but reacts correctly on single keystrokes. Sometimes hitting next image several times helps and it runs fluendly again. Mostly if you viewed all images in the folder it runs smoothly.
