How to disable the Viewer?
Menedas
Post by Menedas »
How can I say XnView to open associated files in fullscreen and when I press enter it should go back to the browser?
If I mark two pictures in a directory and press enter the viewer opens, but I want to watch them in fullscreen e.g. to compare the pictures. How can I change this?
Sorry, I'm no fan of the Viewer because I don't need it.
ckv
Post by ckv »
Indeed you are right. Same thing happens in the latest 1.9 alpha. It's probably a bug. :bug: I don't think it's suppose to work like that.
ckv wrote:Indeed you are right. Same thing happens in the latest 1.9 alpha. It's probably a bug. :bug: I don't think it's suppose to work like that.
Yes, right
Yes, right
Hum, i can't reproduce it???
ckv
Post by ckv »
xnview wrote:Hum, i can't reproduce it???
LOL Pierre. Maybe you fixed it already. :mrgreen:
I think I know what's the problem. The bug doesn't occur if Enter is set to to switch between "Browser > Fullscreen > Viewer", but if it set to "Browser <> Fullscreen | Viewer <> Fullscreen" it should occur.
Menedas
Post by Menedas »
With ENTER to switch between:
It still works wrong. If you select two or more files in the browser to watch with ENTER it goes from Browser to Viewer.
