Hello
I would like to convert 200 gif images with a puzzle filter to have a draw like this : http://alenkasprintables.com/freeprinta ... epiece.png
Is it possible with xnview ? If no how can i do ?
I know is it possible with the gimp but i dont know if it can do a lot of files in one time.
Thanks a lot.
Puzzle filtre ?
- Forum Librarian
Re: Puzzle filtre ?
General Support » Binary(b/w), edge detect, outlines?
- Forum Librarian
Hm, isn't reducing the pictures to b/w outlines — at least in part — what you're looking for
... or would you like to merge the GIFs with some kind of puzzle overlay?XnTriq wrote:
- Mehdi Plugins: Fine Threshold (free)
Unlike the traditional threshold command of Photoshop, the plugin Fine Threshold allows to get quickly, anti-aliased and sharp shapes.- Stoik Imaging: Color By Number ($19.95)
Color By Number lets you to convert photo to a paint-by-number pattern. Just scan the photo or load graphics file from disk, choose the brand of paints/crayons to be used and the program will convert your photo to a paint-by-number pattern optimized for the palette you have chosen. You can print the pattern together with color key.
antisa
Troken
Antisa: No, dont think there is a feature like that, but you might find a photoshop-plugin on the internet that does what you want, and you could use with XnView.
I think this one is free:
http://www.panosfx.com/index.php?option ... &Itemid=27
This costs a few bucks:
http://graphicssoft.about.com/gi/dynami ... avbros.com
