Batch Rename
Batch Rename
Post by Guest »
1. Rename should not change file extension. To-lower and to-upper case is allowed.
2. Batch rename should have multiple templates, which should be created by user, saved and loaded when required.
3. How to rename the following: IMG_1234.JPG --> 2006-09-18_15h22m_1234.jpg ? Currently I'm using "THE Rename" and "Exifer" for this rename. XnView would benefit implementing flexible renaming.
4. An option for powerful users is to use regular expressions notation.
Dreamer
Re: Batch Rename
Post by Dreamer »
Anonymous wrote:1. Rename should not change file extension. To-lower and to-upper case is allowed.
1. I don't understand, you can disable/configure everything there.
3. Use the Insert button to insert what you need. More in the FAQ.
Dreamer
Danny
Post by Danny »
Yes, can we please have regular expressions for the replace text field?
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
