I cannot get this to work:
nconvert -out jp2 -q 60 -o output.jp2 input.jp2
It creates output.jp2 just fine, but the quality is at 100%. In my tests I can put any number in place of the 60 and it does the same thing.
If I save the file with XnView with a quality setting of 60 the file goes from over 200K to 44k but looks just fine.
How do I get nconvert to save at the '60' quality level?
Jorgie
Using quality (-q) with jp2 (-out jp2) has no effect
jedijorgie
Re: Using quality (-q) with jp2 (-out jp2) has no effect
Regards. Pierre.
Strange, i have tested with NConvert v4.11, and all is ok!jedijorgie wrote:I cannot get this to work:
Regards. Pierre.
jedijorgie
that is really strange
I just downloaded and reinstalled. Here is what I am seeing.
I started with http://jorgie.org/initial.jpg which is 266,223 bytes.
I then ran:
Which created http://jorgie.org/nconvert60.jp2 which is 425,451 bytes!
I then opened that in XnView and saved it as XnView60.jp2 with the quality set to 60.
That created http://jorgie.org/XnView60.jp2 whis is 71,061 bytes!
So I ask again, how do I get nconvert to output the 71,061 version of the file that XnView produces? Am I using the wrong setting with nconvert?
Jorgie
I then ran:
Jorgie
Re: that is really strange
Regards. Pierre.
No, sorry, there is a little bug. Quality is not used (ratio 1:20 is used).jedijorgie wrote:So I ask again, how do I get nconvert to output the 71,061 version of the file that XnView produces? Am I using the wrong setting with nconvert?
Regards. Pierre.
artwork
artwork
