(1.82.4 de) Crashes until i disable an option...
New_Guest
Post by New_Guest »
Hi
I'm new with XnView and the following problem:
XnView crashes until i disable the following option:
In german:
Optionen/Bildansicht/Dateien -> "Nächstes Bild im voraus lesen"
in english:
(Due to my installation is german i have to translate now)
Options/Picture View/Files -> "Read next picture in advance" (or so...)
I use XP Prof. with SP2. Any suggestions?
Regards, Roman.
pivot
Post by pivot »
Had the same problem. Worked when disabling option. Tnx!
