A: XnView does not remember last normal window config
Troken
Post by Troken »
Hi!
Sometimes I like to drag-n-drop images directly from the browser to, say, an email or InDesign. To do so I have to klick on restore window (in opposite to maximize window), and drag-n-drop the image. But XnView never remembers how I left the last restored window. It always goes back to some default configuration, which looks funny to me. Can this be fixed?
Important: it does not always happen:
1. If you maximize -> restore -> maximize -> restore etc. XnView remembers window config (hight, width and all) = OK!
2. If you close XnView with a restored window, it remembers = OK!
3. If you close XnView with a maximized window, dang, it forgets the last restored window and falls back to a default restored window next time you klick restore = BAD! :bug:
A similar matter I adressed a couple of months ago, regarding that XnView falls back to restored window when capturing, even though XnView was maximized when capturing. XnView does not remember being maximized:
http://newsgroup.xnview.com/viewtopic.p ... =minimized
V 1.90 A
Re: XnView does not remember last normal window config
Troken wrote:Hi!
Yes, i'll fix it
Olivier_G
Re: A: XnView does not remember last normal window config
Post by Olivier_G »
Troken wrote:3. If you close XnView with a maximized window, dang, it forgets the last restored window and falls back to a default restored window next time you klick restore = BAD! :bug:
I confirm this bug with Beta 6.
Olivier
Troken
Post by Troken »
Yes, I've experienced it in B6 too.
Troken
Retested in 1.90.2: OK!
Post by Troken »
OK, I've tested this issue in version 1.90.2 and the problem is fixed. Please close this thread. :)
Re: Retested in 1.90.2: OK!
Troken wrote:OK, I've tested this issue in version 1.90.2 and the problem is fixed. Please close this thread. :)
Thank you for verifying the bug fix, Troken.
-> Closed.
