I need to convert some files which have a % character in it (e.g. 3Chinesen_Z%c3%bcrich.png). Nconvert tries to substitue the percentage character, is it possible to escape it?
Peter
Filenames with % character
Re: Filenames with % character
Could you try %%?szhrmp wrote:I need to convert some files which have a % character in it (e.g. 3Chinesen_Z%c3%bcrich.png). Nconvert tries to substitue the percentage character, is it possible to escape it?
szhrmp
% filenames
%% wont work, what happens that nconvert replaces each % with the original file name.
the %% is only required if you put the command in a bat file (which I don't do)
Re: % filenames
Right, so i'll fix itszhrmp wrote:%% wont work, what happens that nconvert replaces each % with the original file name.
