Second Browser/File List Window
I don't know did some one already suggest this, but...
Why not just allow more than one browser tab? So this way you could just open two or more browser tabs and use window tiling. Also some kind of docking / lock for tiled browser windos would be creat.
Hopefully some one understand what I mean :)
I don't like the idea of adding another browser window in the normal layout, as it really becomes a over-the-top "File Manager" feature.
Using a File Manager (or even a second instance of XnView) and/or some use of "Copy/Move To Folder" is usually fine, no?
See: it was understandable... although I had some trouble with the "docking/lock" feature
Olivier
Yeah, I much more prefer this way of doing things...ckv wrote:Why not just allow more than one browser tab? So this way you could just open two or more browser tabs and use window tiling.
Also some kind of docking/lock for tiled browser windows would be great.
Olivier
Oliver_G,
You're right, I wouldn't give up using "xplorer2 pro" for dual pane support in XnView.
This is something that could be a "heated debate" topic for some.
Win11 x64 24H2, Hard Disk Sentinel Pro, MS PowerToys, Process Lasso Pro, Windhawk and Wintoys
Yeah and this probably would be easily done without much extra coding.Olivier_G wrote:Yeah, I much more prefer this way of doing things...
Olivier
And about the docking/lock, this can be explain by example:
Open two images in XnView and tile them horizontally. Now if you resize XnView main window the tiled image windows don't change their size with the main window. So it could be great if you could dock them to the main window size and lock the windows size so you cant move / change their size.
I want just another mode/layout with two file lists, two previews and file manager's hotkeys - Tab, F5 ,F6 and Insert/Space - other hotkeys works already in xnview (F2, F3, F4, F7, DEL, Shift+DEL...).
This layout could have its own size/position.
I don't want any special file manager's features.
Main advantages:
- you could copy/move files easily as in file managers with F5/F6
- you could see preview of images you want copy/move (impossible in file managers)
- you could see details of several images in different folders at once
- no need to move and resize two instances of xnview and then move and resize back
- no need to switch between two instances of xnview (and other opened windows) with alt+tab
It would be the same as current "Tab" feature, just switching would be with Tab key and it would be in the same window.
Copy/Move F5/F6 features would be the same as current "Copy to/Move to" features, just target directory would be always directory in other file list on the other side.
| folder | preview | folder | preview |
| tree | | tree | |
| image1.jpg | image5.jpg |
| image2.jpg | image6.jpg |
| image3.jpg | image7.jpg |
| image4.jpg | image8.jpg |
Main advantages:
Dreamer wrote:But I did't meant "thumbnails", I meant preview imageJohnFredC wrote:This is patently not true...Main disadvantage of file managers like Total Commander is that you can't see preview image
...Other side-by-side file managers that do show thumbnails include SpeedCommander, DOpus, Servant Salamander, Frigate, FreeCommander, and many others.
I'm using Servant Salamander - I can see preview image there, but only after pressing F3, then Escape and so on...
I need to see preview image always, while I copy/move... images, like this
Any (freeware) program knows thatCode: Select all
+---------------------------------------+ | | | preview | | | +-------------------+-------------------+ | image1.jpg | image5.jpg | | image2.jpg | image6.jpg | | image3.jpg | image7.jpg | | image4.jpg | image8.jpg | +-------------------+-------------------+
To throw in my 2 cents, this is how i would like to use it:
One folder tree is enough for me.
| | image5.jpg |
| folder | image6.jpg |
| tree | image7.jpg |
| | image8.jpg |
+--------+ image5.jpg |
| pre- | image6.jpg |
| view | image7.jpg |
| | image8.jpg |
I don't need folder tree at all, but som users need it (more above) - therefore it should be able to disable it.Danny wrote:To throw in my 2 cents, this is how i would like to use it:One folder tree is enough for me.Code: Select all
+--------+------------------+ | | image5.jpg | | folder | image6.jpg | | tree | image7.jpg | | | image8.jpg | | |------------------+ +--------+ image5.jpg | | pre- | image6.jpg | | view | image7.jpg | | | image8.jpg | +---------------------------+
All I need is this - file manager system with one preview:
| preview |
Great idea. Support!
I made a similar request before...
Dual pane file browser [with visuals]...
http://newsgroup.xnview.com/viewtopic.p ... sc&start=0
What's Up...
Still actual...
| folder | | | folder | | | preview | preview | |
| tree | | | tree | | | | | |
+----------+ preview | preview +----------+ | tree +----------+----------+ tree |
|image1.jpg| | |image5.jpg| | |image1.jpg|image5.jpg| |
|image2.jpg| | |image6.jpg| | |image2.jpg|image6.jpg| |
|image3.jpg| | |image7.jpg| | |image3.jpg|image7.jpg| |
|image4.jpg| | |image8.jpg| | |image4.jpg|image8.jpg| |
| folder | | | folder | | folder | preview | preview | folder |
| tree | | | tree | | tree | | | tree |
| |image1.jpg|image5.jpg| | | | | | |
+----------+image2.jpg|image6.jpg+----------+ +----------+----------+----------+----------+
| |image3.jpg|image7.jpg| | | image1.jpg | image5.jpg |
| preview |image4.jpg|image8.jpg| preview | | image2.jpg | image6.jpg |
| folder |image2.jpg|image6.jpg| folder |
| tree |image3.jpg|image7.jpg| tree |
| preview | preview |
Re: Second Browser/File List Window
i like this method the best, because it still emphasizes the file manager aspect. it allows efficient moving of files/folders between panes.
| tree | | | tree |
