Start slide show automatically and manually with hotkey
Dreamer
Post by Dreamer »
I've got another feature request, could You add this, please?
Start slide show automatically in fullscreen with all images in folder, starting with current (opened) image
And start and stop slide show manually with one hotkey (space for example, like in video players, or other) if "start slide show automatically" is disabled
Thank You very much :)
Re: Start slide show automatically and manually with hotkey
Dreamer wrote:I've got another feature request, could You add this, please?
Ok, thanks for your suggestions.
Post by Guest »
Fantastic. That should be very convenient, someday.
paul_ahb
Post by paul_ahb »
I'd also like to add myself to the list of poeple wanting this feature. In addition, could there be an option to recurse subfolders aswell?
Also, I noticed that the sld files cannot be associated with xnview. When I try to launch xnview with my sld file as the parameter I get the error: "format of the file ... could not be determined". I expected that the aplpication would open and the slide show play automatically.
Paul
paul_ahb wrote:...Also, I noticed that the sld files cannot be associated with xnview. When I try to launch xnview with my sld file as the parameter I get the error: "format of the file ... could not be determined". I expected that the aplpication would open and the slide show play automatically.Paul
Please have a look at Opening a slide show file, this might solve this issue.
paul_ahb
Post by paul_ahb »
It does thankyou. I missed that thread with my searching, sorry. :(
Paul
paul_ahb wrote:It does thankyou. I missed that thread with my searching, sorry.
Good - no problem!
Dreamer
Post by Dreamer »
Dreamer wrote:...And start and stop slide show manually with one hotkey (space for example, like in video players, or other)...
This is in new version 1.74 (button), thanks Pierre.
Could you add a hotkey (space) for start (and stop) slide show (exactly what that button does - for usage in fullscreen too) ? Thanks.
Dreamer
Post by Dreamer »
Thanks again for "manual slide show" feature (button). It's great feature, but now it's possible to use it in viewer only, not in fullscreen.
Could you add a hotkey (space) for this feature, please?
I think, it wouldn't be too hard to implement a hotkey, because a feature already exists...
Thanks!
P.S. Till then it's possible to use this feature in fullscreen easy with a mouse - click middle mouse button (MMB), click on Slide show button and click MMB again, for stop slide show do the same again
Dreamer wrote:Thanks again for "manual slide show" feature (button). It's great feature, but now it's possible to use it in viewer only, not in fullscreen.
Thanks!
Ok i'll add a hot key to start the auto slide show
Dreamer
Post by Dreamer »
xnview wrote:Ok i'll add a hot key to start the auto slide show
Thank you!
Dreamer
Post by Dreamer »
Could you add "Slide show" to RMB context menu too? With a hotkey: "Slide show .......... Space". Thanks.
Dreamer
Post by Dreamer »
(moved)
stooges wrote:Shortcut key to "Slideshow Start" on view mode (ACDsee uses "Pause" key - press again to stop) - also add this function the the context menu and the main menu (couldn't find it there)
Dreamer
Post by Dreamer »
I've got some problem with a 'Pause' key in one movie player, it's maybe a windows problem, so I suggest to add custom hotkey or ability to change ('Space' or 'Pause') to prevent possible problems.
Dreamer wrote:Could you add "Slide show" to RMB context menu too? With a hotkey: "Slide show .......... Space". Thanks.
in view mode?
