New versions of XnView crashing after I installed Firefox
ixnay
Post by ixnay »
I did the bad thing. Updated two software packages on the same day. Now I find that after updating Firefox to latest version my updated XNview will not start. Same thing happening on two different machines - one Intel and one AMD so its not my hardware at fault. Anyone else found this? One one machine I had to do a system restore to yesterday and now it works. Since then I updated Firefox again and XnView still works so it must be something in the new version.
Hers a thing though - it is fine when running in admin mode on XP Only when I log in with the limited user account does it crash.
Re: New versions of XnView crashing after I installed Firefo
ixnay wrote:I did the bad thing. Updated two software packages on the same day. Now I find that after updating Firefox to latest version my updated XNview will not start. Same thing happening on two different machines - one Intel and one AMD so its not my hardware at fault. Anyone else found this? One one machine I had to do a system restore to yesterday and now it works. Since then I updated Firefox again and XnView still works so it must be something in the new version.
Try to rename all xnview.ini files, and remove cache folder (xnview's folder)
