Converting WBZ to JPG - won't do it
shelc
Post by shelc »
I have used XNView in the past to convert my webshots downloads (wbz) to jpegs, but I had some computer problems and got a new hard drive, so I lost my programs and files. Anyway, I decided to download the latest release and convert the new pictures I downloaded. When I selected the files I wanted converted, I got a warning that said the following:
Format of the file (file location and name).wbz could not be determined
Also, when I went into the Options and to Associations, Webshots wasn't listed. Why is this, and how can I fix that? I know I can get another program to convert my webshots pictures, but I like XNView, so if I could get help resolving this issue, I'd really appreciate it. Thanks.
-Michelle
marsh
Re: Converting WBZ to JPG - won't do it
Post by marsh »
shelc wrote: Also, when I went into the Options and to Associations, Webshots wasn't listed. Why is this, and how can I fix that? I know I can get another program to convert my webshots pictures, but I like XNView, so if I could get help resolving this issue, I'd really appreciate it. Thanks.
Please look at FAQ "Does XnView support graphic format .xyz?" and its follow-up mentioning the 'Use all formats available' option- which is used for the rarest file types.
