Additional information for some functions? (SDK)
MaierMan
Post by MaierMan »
First of all Thx a lot (again) for this fantastic piece of work :D
Alright, I have some questions about some functions of the SDK...
The tolerance parameter of gflAutoCrop will be used how?
Is it some kind of percentage.
How will it work.
And what does gflAverage exactly do?
Parameters (filter_size) work how?
Re: Additional information for some functions? (SDK)
MaierMan wrote:The tolerance parameter of gflAutoCrop will be used how?
It's the maximum difference between pixels!
It's a the filter size, so 3, 5, 7, 9, 11, 13
MaierMan
Post by MaierMan »
First of all thx for answering.
But What excatly will gflAverage do?
MaierMan wrote:But What excatly will gflAverage do?
It's a filter like blur, an average between all pixels!
MaierMan wrote:...But What excatly will gflAverage do?
MaierMan, before asking you could try and check out the effects & filters in XnView. FAIK, often the GFL functions are named like the effects and filters.
mbetrafa
What about the color tolerance of auto-crop?
Post by mbetrafa »
How can I determine the background with a certain color tolerance before auto-crop?Also when I write 200 it crops,but when I make the tolerance 500, it does not make anything. When tolerance is more,should it crop if it crops for a lower value?
