I have a little question:
Can I use the internal methods from XnView with an external program?
More precise: I need to automatically add some text + generated numbers to scanned images out of MS Access (VBA). Therefore I need to rotate that image, add the number, rotate it again and add the text.
Can I control XnView with an external program as I can control MS Excel for example?
Regards,
Robert
Use XnView internal methods via external program-code
Re: Use XNView internal methods via external program-code
Regards. Pierre.
No, but i think that you can take a look at GFL SDKksb wrote:I have a little question:
Can I use the internal methods from XNView with an external program?
Can I control XNView with an external program as I can control MS Excel for example?
Regards. Pierre.
