where are the Hidden Options at 1.70 ??
In version 1.67 i can hide the menus in the xnview.ini file using:
[Hidden]
OpenHex=1
This won't work in 1.70 ??
How do i do that ??
Greetings
Ralf
Hidden options don't work in 1.70.4
Re: XnView 1.70.4 - Citrix
The hidden options have been introduced in XnView 1.67 and should still work in 1.70. If they don't, this is a clear bug. We'll check and let you know here.MBV wrote:Hi,
Version 1.67 i can hide the Menues at the xnview.ini File
[Hidden]
OpenHex=1
How do i do that ??
Greetings
Ralf
Grüße,
Helmut
Re: Hidden options don't work in 1.70.4
I've just checked and indeed, in XnView 1.70 none of the Hidden options work. Pierre will check and correct this, soon.MBV wrote:Hi,
[Hidden]
OpenHex=1
How do i do that ??
Greetings
Ralf
