EPS and Windows 2000
Post by Guest »
Hi. I have 2 Windows 2000 machines with libgfl254 and GhostScript 8.54 that will not load EPS files. It returns error 6, unknown format. The same file loads fine on Windows XP. I have also tried it with XnView with the same results (displays the image in XP, displays an error "format of the file <> could not be determined" on 2000). The images load fine in GSView on Windows 2000.
Has anyone else seen this?
Let me know if you need any more information.
Thanks!
Matt Wagner
Re: EPS and Windows 2000
Post by Guest »
Nevermind. AFPL vs GPL problem.
