Process multiple folders and leave output in original folder
Ewek1
Post by Ewek1 »
I want to process multiple folders and have the output replace the original file in these folders. I don't want to specify the output location for each folder one by one. Is this possible?
Re: Process multiple folders and leave output in original fo
Ewek1 wrote:I want to process multiple folders and have the output replace the original file in these folders. I don't want to specify the output location for each folder one by one. Is this possible?
Will be added in next release
Ewek1
Was this implemented?
Post by Ewek1 »
Pierre-
I was wondering if this feature was ever implemented?
foxyshadis
Post by foxyshadis »
Sure, it's pretty simple. You first open batch convert, add your folders, check "use original path as output" and set overwrite to "replace". Make sure you've got the right format, set your transformations/script, and go; all existing images will be replaced, except those in a different format.
