Registration does not work on Citrix Metaframe
MBV
Post by MBV »
after installing XnView at a Citrix Server, i enter as Administrator our license at Info->Registration. After this i logon as normal user and check Info-> About. I get the info that Xnview is unregistered..............
It looks like that XnView stores the Registration Information in HKEY_CURRENT_USER
How can i fix it ? My user asking me why we don't register :wink:
CU
Ralf
Re: Registration does not work on Citrix Metaframe
MBV wrote:Hi,
Right, looks as if the Registration information is stored in the wrong location. On normal systems this problem does not become that obvious, but in a Terminal Server environment this surely does.
Pierre will investigate this and then reply here in the newsgroup. Since you are registered user/company, he will also send you news on your problems via mail.
Post by Guest »
How about a Fix ??
Anonymous wrote:How about a Fix ??
You can try the 1.74 RC4 to test, i'll fix the problem.
