When I tag a few images (ctrl+T) and then select filter by tags, all images disapear but the tagged ones.
If I click another folder and back to the previous folder, tagged images and other are not visible. Now no files are visible. If I go back to "filter>all" no files are visible.
In order to fix this i have to go to view>tags>show tag box and uncheck it and make sure my filter is set to all. Now when I switch the folder files will be shown.
reference
http://newsgroup.xnview.com/viewtopic.php?t=9091
A3: Tags - no files in folders visible
Re: A3: Tags - no files in folders visible
It's normal, tagged files are not kept, but there is a bug for filter>alldcakovan wrote:When I tag a few images (ctrl+T) and then select filter by tags, all images disapear but the tagged ones.
When switching to another folder, the tagging is lost which is normal.xnview wrote:It's normal, tagged files are not kept, but there is a bug for filter>all
-> Closed.
