Browser window size
Garfunkel
Browser window size
Post by Garfunkel »
When I select 'Fit Window to image', view an image and then go back to the browser view the browser window doesn't remember its size before viewing. For example if I view file (110x100) the browser shrinks to that size! I don't like the idea. The browser should keep its size independently just as ACDSee does for instance. Plz, fix.
Re: Browser window size
Garfunkel wrote:When I select 'Fit Window to image', view an image and then go back to the browser view the browser window doesn't remember its size before viewing. For example if I view file (110x100) the browser shrinks to that size! I don't like the idea. The browser should keep its size independently just as ACDSee does for instance. Plz, fix.
I couldn't reproduce your problem. Which Windows platform do you use? Which XnView version (I assume 1.70.4)? Could you please send me your .ini file (My mail address is [email protected], please remove '-nospam')
Greetings,
Helmut
