Hi! First i'd like to tell you: amazing program! And it's FREE! Can you believe it??
With that being said, as an old ACDSee user i'd like to request a little feature: In ACDSee i was able to add a description for directories, too (those descript.ion files, you know?). With XNView i can only add those descriptions to files - or at least my folder descriptions from ACDSee are not showing up in XNView. So would you mind doing something about it?
Thanks in advance
Dan
Folder Descriptions
Anika
Danny
See? I'm not the only one who could make good use of this. Any chance to get this in? Like to use "descript.ion" files by default (since they're already being used for pictures, right?) and an option to use "file_id.diz" files instead as Anika requested.Anika wrote:I create my folder description with CD2HTML. It is stored in the file file_id.diz in the folder. It would be great if I could see this descriptions in the list view (F10).
Anika
Danny and Anika,
thank you for your suggestions. To your suggestions make sense. The folder information could be displayed in the pane/area of the preview, whenever selecting a folder in the folder tree or in the file list (right side).
When supporting other program's file/folder information, we should make sure that the most common programs are supported. E.g. Total Commander is a candidate, not sure whether Total Commander supports folder informations.
Greetings,
Helmut
Greetings,
Helmut
I've never heard of Total Commander before.helmut wrote:When supporting other program's file/folder information, we should make sure that the most common programs are supported. E.g. Total Commander is a candidate, not sure whether Total Commander supports folder informations.
And i think ACDSee is a very well-known and wide-spread program. So it sure would make sense to support their way of folder descriptions (just like the pictures in "descript.ion" files), no? I thought it should show up in the browser's description pane like this:
Just my 2cents.
Greets
Danny
Dany et al,
thank you Dany for the post with the screenshot , which make things clear. For the non-Germans: "Beschreibung" is "Description" in English.
The column description can be seen in detail view, only, also I wonder where the description of the current folder is shown. Any ideas? Or is there no need for displaying info for the current folder?
Greetings,
Helmut
PS @Dany: Perhaps you can make an English version of the Screenshot and replace the current one on your server.
Greetings,
Helmut
Danny
You're welcome.helmut wrote:Dany et al,
thank you Dany for the post with the screenshot , which makes things clear. For the non-Germans: "Beschreibung" is "Description" in English.
Well, i don't really need the description for the currently displayed folder but ACDSee has a field in the status bar at the bottom of the window which shows the current folder's description. So you may do it like that since space shouldn't be an issue, i think. But like i said, personally i don't need to have that.
On a sidenote: it seems that XNView can already read folder descriptions from "descript.ion" files, but it can't write them.
Greets & thanks for taking the time
Danny
Re: Folder Descriptions
Ok, i'll add itDanny wrote:With that being said, as an old ACDSee user i'd like to request a little feature: In ACDSee i was able to add a description for directories, too (those descript.ion files, you know?). With XNView i can only add those descriptions to files - or at least my folder descriptions from ACDSee are not showing up in XNView. So would you mind doing something about it?
Danny
Thanks a lot!xnview wrote:Ok, i'll add itDanny wrote:With that being said, as an old ACDSee user i'd like to request a little feature: In ACDSee i was able to add a description for directories, too (those descript.ion files, you know?). With XNView i can only add those descriptions to files - or at least my folder descriptions from ACDSee are not showing up in XNView. So would you mind doing something about it?
