I just installed the ASP component and registered the dll file, but when I try the examples that are included I get constantly this error.
GflAx.GflAx.1 (0x80004005)
Error to open file
I also tried to write some code by myself, but I always get this error. Did I forget something to install?
Somebody got a clue, what I can do about it, cause I'm very intrested in this component, I've heard a lots of good stories about it.
thanks in advance
GFLAX Error "0x80004005 Error to open file" (ASP)
BlackBurn
BlackBurn
Problem solved
the problem is already solved it was a dumb mistake of me, the loadbitmap must have a full path.
Thanks to Pierre for helping me out.
