Trying to read Power Point .PPS file formats.
royhshoemakerAatt.net
Post by royhshoemakerAatt.net »
Downloaded your xnview for windows. Feature list said it supported Power point formats. Once downloaded and installed Power formats do not appear as supported. Are they?
Re: Trying to read Power .PPS file formats.
royhshoemakerAatt.net wrote:Downloaded your xnview for windows. Feature list said it supported Power point formats. Once downloaded and installed Power formats do not appear as supported. Are they?
Enable option/general/startup/Use all formats. In FAQ "Does XnView support graphic format .xyz?" you'll find more info.
