I installed XnView 1.70 but was disappointed. I wanted to open wpg files and be able to view them, save as, etc. It says format of the file could not be determined. I used the full exe download.
Am I out of luck?
Thanks,
Brenda
Wordperfect?
Re: Wordperfect?
XnView can only extract picture (not vector) from WPG files!Brenda wrote:I installed XnView 1.70 but was disappointed. I wanted to open wpg files and be able to view them, save as, etc. It says format of the file could not be determined. I used the full exe download.
Am I out of luck?
Re: Wordperfect?
Well it wouldn't even open a wpg file.xnview wrote:XnView can only extract picture (not vector) from WPG files!Brenda wrote:I installed XnView 1.70 but was disappointed. I wanted to open wpg files and be able to view them, save as, etc. It says format of the file could not be determined. I used the full exe download.
Am I out of luck?
B
