Thumbnail Text&Background colour
Koogle
Post by Koogle »
For 1.90 Alpha 2..
Options>Thumbnail>Thumbnail Labels..
Both colour box options for Text and Text Background colour do not have any effect once applied..
Would be nice to change the yellow background colour its defaulted too :)
Also is it possible to have another option that overides the default windows selected colour... that way I can have a different colour thats more suited to the background colours etc I've used in browser mode, when a thumbnail is selected?
V 1.90 <x>
Re: Thumbnail Text&Background colour
Koogle wrote:For 1.90 Alpha 2..
You must be in 'Thumbnails & labels'
ok, i'll try to add it
Koogle
Post by Koogle »
I finally found out what the problem was..
Options>Browser>File List> [Use Colour Based On File Format] was on.
Turned it off and now I can see the problem I had earlier isn't a problem at all.. its just been over ridden by this other option.. I suppose what would be nice if the user could choose the background colours per file format?
The problem is solved, but there is still a request open. -> Postponed.
Initial request has been solved.
Koogle, could you please start a new topic for this:
Koogle wrote:I suppose what would be nice if the user could choose the background colours per file format?
Koogle, please place a post in forum "Suggestions" for your above request.
-> Closed.
