How to know if IPTC can be saved?
kurka666
Post by kurka666 »
Hi
Is it possible to know if a file type supports saving of IPTC without trying first and then checking the error response?
The gflFormatIsWritableByName/Index may return Yes even if metadata can not be saved (for example for .BMP)
Thanks
Henrik
Re: How to know if IPTC can be saved?
kurka666 wrote:Hi
No, i must add a fuction for that. Currently you have only JPEG...
kurka666
Post by kurka666 »
ok - that's what I thought. For now, I'll just hard code a check for JPG or others.
Thanks!
