-rotate 90 doesn't work
rockstar1707
Post by rockstar1707 »
Can someone please tell me why the following script doesn't work:
I have to mention that rotating for some "non-right" angle works, for example:
will do the right job.
It doesn't work for 90, 180 and 270 degrees.
Thank you very much for your answer.
Re: -rotate 90 doesn't work
rockstar1707 wrote:Can someone please tell me why the following script doesn't work:
I'll fix this problem asap
