Describe on folder
This is great, but the handling should be as for files.
1. I write a description and save it.
2. I want to change or add something to the description.
3. In the RC1 I recall the description but the text field is empty and I have to rewrite everything.
Conversion dialog
You have changed the script file structure so that now the selection of "Decrease only" is saved. But my old script files are now not fully imported. I have a script that does four things:
resize( 1 linear 200 0 )
crop( 0 0 100 200 )
resize( 1 linear 0 120 )
sharpen( 31 )
When I use this old script in the RC1 only the two resize steps are shown.
So I have to change my script to:
resize( 1 linear 200 0 -1 )
crop( 0 0 100 200 )
resize( 1 linear 0 120 -1 )
sharpen( 31 )
I will have to do it first in a text editor otherwise my lines after resize will be dropped. Just for others who will have the same problem: in TextPad the regular expressions are: search ^resize[^)]* and replace by & -1
-1 is for decrease only. 0 would be for no selection.
							RC1: Folder description, 'Resize' in scripts
XnView 2.04, 2.13 Windows 2000 SP4 and Windows XP SP3 and Windows 7 64bit
						Re: 1.74 RC1: Folder description, 'Resize' in scripts
Confirmed. From my point of view a bug.Anika wrote:Describe on folder
 Scripts should always be compatible and manual changes should not be needed. Perhaps Pierre can do something about this.Anika wrote:Conversion dialog
Thank you & Grüße,
Helmut
