Fullscreen (from browser) enlarge is always low-qual
foxyshadis
Post by foxyshadis »
I hope it's possible to fix this soon. Nearest-neighbor is just too ugly to bear, even if bilinear isn't perfect it's still much better. The workaround of entering view, then fullscreen, is annoying and quite slow when changing often (as I have a habit of doing). I don't quite understand why there are two different but outwardly similar fullscreen modes, but I guess that's important to the internals.
Since there was no reply to my query in the other thread (and apparently no confirmation of non-working by the OP) I thought maybe I should post here instead. Sorry if that's bad.
V 1.90 B6
Re: B6: Fullscreen (from browser) enlarge is always low-qual
foxyshadis wrote:I hope it's possible to fix this soon. Nearest-neighbor is just too ugly to bear, even if bilinear isn't perfect it's still much better. The workaround of entering view, then fullscreen, is annoying and quite slow when changing often (as I have a habit of doing). I don't quite understand why there are two different but outwardly similar fullscreen modes, but I guess that's important to the internals.
When you go to the fullscreen (from browser), you are always in low quality??? Do you have option/View/High quality/Reduce?
foxyshadis
Reduce works fine, always HQ there. It's enlarge that doesn't. All three HQ options are checked. Resize mode is "fit to window, all", but other fit options act the same way. In "large only" modes, using / to fit results in the same point sampling behavior. Delayed HQ for fullscreen is off (it also works for reducing large images and does not work for enlarging small ones).
Any image that is shrunk is smoothed properly and looks nice.
Sample:
Opened directly from browser
Opened in view mode, then fullscreen from there
Extreme Sample: (Not really meant for full-screen either way)
(And just for fun, why lanczos is awesome and a resize sample from my own research.)
Olivier_G
Post by Olivier_G »
Quite impressive result!
Olivier
foxyshadis wrote:Reduce works fine, always HQ there. It's enlarge that doesn't. All three HQ options are checked. Resize mode is "fit to window, all", but other fit options act the same way. In "large only" modes, using / to fit results in the same point sampling behavior. Delayed HQ for fullscreen is off (it also works for reducing large images and does not work for enlarging small ones).
HQ zoom works to reduce picture, not to enlarge them... But a need for a future version!
The pictures used are always smaller than window/desktop, right?
Sorry about my reply, i have not readed correctly, i need holidays :-)
So yes currently fullscreen (browser) doesn't enlarge in HQ
foxyshadis
Ah, does that mean this fix will be postponed until the next release then? :( I think we all need that vacation. =p
Olivier_G
Post by Olivier_G »
foxyshadis wrote:Ah, does that mean this fix will be postponed until the next release then?
I guess so...
I hope version after 1.90 will cope with both '2 fullscreens' and 'HQ zoom speed' issues at the same time! (+better buffering 1 & 2 too... :P )
Olivier
foxyshadis
Even though this wasn't listed as fixed, and it was going to be postponed, it seems our man has made this happen anyway. =DDD
The only problem is that it seems to use the wrong option. Only HQ "Enlarge" -> HQ Fullscreen w/ fit. Only HQ "Fit to Window/Desktop" -> no HQ. Other than that, very cool.
foxyshadis wrote:Even though this wasn't listed as fixed, and it was going to be postponed, it seems our man has made this happen anyway. =DDD
Now i use only option/View/Reduce & enlarge!
foxyshadis
That makes sense. Will the third option be removed from the UI for the final, then?
foxyshadis wrote:That makes sense. Will the third option be removed from the UI for the final, then?
Yes, i think that i'll remove the 'Fit desktop' option...
Olivier_G
Post by Olivier_G »
Status in 1.90 RC2:
- 'Reduce' HQ works perfectly (both in Viewer & Browser's fullscreen)
- 'Enlarge' HQ works perfectly in Viewer and works in Browser up to screen size (Low Quality is used when greater than screen size).
As 'Enlarge' HQ is a CPU/RAM resource hog (check that suggestion), it may actually be best not to change that behaviour for 1.90.
'Fit desktop' option has been removed. That's ok for my needs.
-> postponed?
Olivier
