Copy and Paste
Accalon
Copy and Paste
Post by Accalon »
What I am doing:
I open a pic in new Window, Mark the full Image or an Area, then press ctrl+c (for copy) or do it with the Menu, then go to an other App like an eMail or a Word Doc and press ctrl+v for paste (or over the menu)
Result:
In Version 1.8x i get the Image or part of it in the other App. In V 1.9 i get e link to the Image like. U:\Privat\Media\MiscPhotosAndGrafics\FunPic\Das%20Bike[1].jpg
Is it a Bug or a Feature :?
(my first time here..... and 1 thing i have to say..... XnView is really a greate tool, I use it very intensive since about 1 Y...... thx)
Greetings from old Switzerland
Accalon
XnView 1.90 <x>
Re: Copy and Paste
Accalon wrote:What I am doing:
Result:
Accalon
When you copy picture, i add picture and text path in clipboard
Accalon
Post by Accalon »
did a bit more testing......
It's right, when i copy a pic as ex. to Photoshop it's ok. When I do it in Word (Office 2007) or Mail and I do it over the Menu "Insert as" it's working. So I thougt, it's a changed default beaviour in Office 2007.....
But when I do it in XnV 1.82.4 with "ctrl+v" it's different, I allway get the Image....
Could it be, because you only added the pixels in V 1.8x and now in V 1.9x also the Link into Clipboard. Is it possible to steer the behaviour from your side?
Accalon wrote:did a bit more testing......
Yes, in 1.8x i'll add perhaps only the bitmap data...
Accalon
Post by Accalon »
thx Pierre and have a good week
surfacecleanerz
Post by surfacecleanerz »
I just realized this post,
Would it be possible, to change this in settings to the "normal" user-desired action: copy the file to clipboard?
My 1.82.4 does the same as 1.90 rc1, copy plain text directory link...(via right click\copy)
Stefan
XnViewFanScratchingHead
change in default Paste behaviour for images.
Post by XnViewFanScratchingHead »
I'm moving back to an earlier version of Xnview (or perhaps back to irfanview) that has the *expected* and standard behaviour of copy/paste for images, that is, copy an image in Xnview, paste the image into Microsoft Word or any other application.
Assuming the user wants only the UNC path is just plain silly. I've been an I.T professional and programmer for 20 years and this kind of 'feature' change just astonishes me!
Great program, but if this is a sign of things to come, Irfanview is going to be my graphics prog of choice.
piliktal ([url=http://newsgroup.xnview.com/viewtopic.php?t=11926]Problem with copying selected part of picture[/url]) wrote:Yes, you are right, of course!
After Ctrl-C, the selected part of picture AND the path/tab title as text are copied to the clipboard. In Word the Ctrl-V get the TEXT from clipboard. In "special paste" it is possible to select what will be copied from clipboard: TEXT OR PICTURE.
After Ctrl-X ONLY the selected part of picture is copied to clipboard, so word gets it (no anything else in the clipboard).
surfacecleanerz
ok, this is a possibility, but I think an option for changing it to the normal behaviour for rightclick copy as normal file copy to clipboard feature would be very useful!
Stefan
HelpDesk-Junky
It seems to be an Bug...
Post by HelpDesk-Junky »
Please change the functionality back to your older style, please...
Post by Guest »
It would be very nice if you can change this setting back to the earlier style.
maybe - if you really want this fug (feature-bug ^^) - you can add an option to disable it.
Re: It seems to be an Bug...
HelpDesk-Junky wrote:Please change the functionality back to your older style, please...
Ok, i'll add a hidden setting in 1.90.3
CopyClipboard=0 (filename & image), CopyClipboard=1 (image)
For symmetric reasons and flexibility I think you should have:
1=Copy filename
2=Copy image data
3=Copy filename & image data
Not sure whether there is a need to copy the filename only.
Absolutely !
—> helmut
• Hi !
1=Copy filename
2=Copy image data
• Yes, I agree totally !
…Not sure whether there is a need to copy the filename only.
• Personally, I need this very often, I'd even requested it a while ago,
vs. the file listing creation, quite inappropriate in the case…
- I might be able to copy several names too, i.e. when selected as thumb nails or in a list of the Browser.
- I would even add again :
4=Copy name¦s and full path¦s
• Anyway, separate commands would be much better, IMHO…
:mrgreen: G.
ouistiti
Post by ouistiti »
:arrow: Clo
I agree totally, and support the four proposed settings ! ♥
Friendly
Paul
1,77245385090552...
