XnView don't read my CorelDRAW Files
Grebnavi
Post by Grebnavi »
Help-me!
My XnView don't reading my CorelDRAW X3 files... type .cdr and .cmx
XnView Version 1.90.3 (Mar 14 2007)
And Now?
Meu programa XnView não está lendo(visualizando) os arquivos do CorelDRAW X3, .cdr e .cmx
XnView Versão 1.90.3 (Mar 14 2007)
E agora?
helmut ([url=http://newsgroup.xnview.com/viewtopic.php?t=4516]how can i open a cdr file?[/url]) wrote:
xnview wrote:
luckyguy wrote:i downloaded xnview but i still can not see crd files.
Please can anybody help me?
XnView can only open cdr files with thumbnail
A bit more precise: XnView can only read and display the thumbnail preview embedded in the CDR file. The thumbnail is embedded by Corel Draw or Corel Photopaint, respectively, when saving the image. The thumbnail is optional, if it's not embedded you won't be able to see anything in XnView browser or image view. Quality of embedded thumbnail is comparatively low, sufficient for browsing but for viewing it's no good.
There's little XnView can do about it because CDR format is a proprietary vector format of Corel.
Related topics:
- CorelDraw cdr files
- Problem opening .CDR files...
Post by Guest »
How I qualify the Thumbnail in the CorelDRAW X3, so that I can visualize the archives in the XnView? In the CorelDRAW when except for the archive already the option is marked miniature.
How embedded the thumbnail preview in the CDR file?
Post by Guest »
Thanks!!
But, I would like to continue seeing my archives of the CorelDRAW X3 for the XnView. How to make with that I come back to visualize the archives in the XnView? I do not want to open, soh to continue seeing the miniatures as before…
Grebnavi
Post by Grebnavi »
I am saving the archives in the CorelDRAW X3 correctly, also selecting the option miniature, at the moment to save. Exactly thus, I do not obtain to visualize the miniatures in the XnView.
I am using version 1.90.3 (Mar 14 2007) of the XnView. I repeat! In the previous version, it did not have this problem!
How to visualize then the CorelDRAW archives in the XnView? How to correct this problem?
Grebnavi wrote:I am saving the archives in the CorelDRAW X3 correctly, also selecting the option miniature, at the moment to save. Exactly thus, I do not obtain to visualize the miniatures in the XnView.
Try Option/General/Use all formats
Grebnavi
Thanks
Post by Grebnavi »
Now Yes! Thanks a lot for the information!
I am gotten passionate by the XnView, and was wild without knowing as to come back to see the miniatures of my archives of the CorelDRAW through it…
Thanks! E Congratulations for the program!
Agora Sim!! Muito obrigado pela informação!!
Sou apaixonado pelo XnView, e estava louco sem saber como voltar a ver as miniaturas dos meus arquivos do CorelDRAW através dele...
Obrigado mesmo!!
E Parabéns pelo programa!!
