Hi, love your program, but still use acdsee due to the 2 things mentioned in title.
I have light sensitive eyes, and very bright colour backgrounds are not good for long periods. So skins would be great, and also the options to change all the background colours. I have found changes for the thumbs and file panes but not the folder tree pane. Also even though I have a dark theme for vista all the menu bars and such are also in grey.
Auto rename.
Folder operations. I would like to see either a second folder tree pane for drag and drop, or an option on right click to move folder from the folder tree pane. As it stands I can only seem to move a whole folder from the file pane, and then I can`t see the pictures contained, unless there is something i`m missing?
Sorry if these have been mentioned before, but I have tried search and browsing!
Folder operations, skins, auto rename
Re: Folder operations, skins, auto rename
dragonsblade71uk wrote:I have light sensitive eyes, and very bright colour backgrounds are not good for long periods. So skins would be great, and also the options to change all the background colours. I have found changes for the thumbs and file panes but not the folder tree pane. Also even though I have a dark theme for vista all the menu bars and such are also in grey.
Pending requests:dragonsblade71uk wrote:Folder operations. I would like to see either a second folder tree pane for drag and drop, or an option on right click to move folder from the folder tree pane. As it stands I can only seem to move a whole folder from the file pane, and then I can`t see the pictures contained, unless there is something i`m missing?
