[OK] Small icon/logo to XnView sites
Locked
Dreamer
Post by Dreamer »
Can you add small icon/logo to XnView sites and this forum for "tabbed" web browsers like Avant, Opera, IE2...
And thanks for new version, I'm gonna test it tomorrow :D
Re: Small icon/logo to XnView sites
Dreamer wrote:Can you add small icon/logo to XnView sites and this forum for "tabbed" web browsers like Avant, Opera, IE2...
Good idea/hint!
For all I know Pierre/Sören simply has to place a 16x16 pixel icon file named "favicon.ico" in the root dir on the web server to make this work.
helmut wrote:For all I know Pierre/Sören simply has to place a 16x16 pixel icon file named "favicon.ico" in the root dir on the web server to make this work.
favicon.ico? Are you sure?
Irving
Post by Irving »
While on the subject of sites, what's wrong with this one? You can't bookmark it without all the extra clicks of going through the front door. And there's two scrollbars, as if this is in frames.
How about a separate door for the forum?
Pretty sure - for all I know Microsoft introduced this "special", non-standard feature and now more browsers support it. For all I know, for Internet Explorer you will see the icon only if you have set a bookmark to that website.
Irving wrote:While on the subject of sites, what's wrong with this one? You can't bookmark it without all the extra clicks of going through the front door. And there's two scrollbars, as if this is in frames.
Not sure what your front door is: Do you use http://newsgroup.xnview.com/ ?
Post by Guest »
That works. :D
You'd never find it from going in the front door, though.
Anonymous wrote:That works. :D
Right. I have just placed a new topic in the "Info" group telling about this short cut.
Dreamer
Post by Dreamer »
Added, thanks.
Locked
