This is GREAT. As you may have seen in the other topic, I was actually looking for something like a Tools | Create thumbnails or similar, so I really didn't notice the new button in the dialog. It does exactly what I suggested, that is create thumbnails automatically for a whole folder tree and it seems it's working fine, apart two small issues:
1. folder thumbnails are not created, so if you've chosen to display the 4-in-1 folder images and you navigate to a folder you still have a moment to wait for the images to be created, though it's not even really annoying since the thumbs in the folder have already been created
2. if you've chosen to thumbnail a big tree with lots of images, of course it takes some time: in such a case I experienced problems in the repainting of the main XnView window and of the dialog indicating the file currently being thumbnailed. It's not also possible to pause or abort the operation.
XnView 1.90 <x>
Thumbnail Cache - Add folder
Olivier_G
Re: Thumbnail Cache - Add folder
You can't click on Cancel??robc wrote: 2. if you've chosen to thumbnail a big tree with lots of images, of course it takes some time: in such a case I experienced problems in the repainting of the main XnView window and of the dialog indicating the file currently being thumbnailed. It's not also possible to pause or abort the operation.
robc
Olivier_G
Very strange, i have the dialog, and i can click on cancelOlivier_G wrote:Confirmed: I can't click on Cancel, I can't switch back to XnView UI if other windows are on top, I can't even move the processing/dialog window......looks like the caching reclaims all CPU for itself...
Do you try on Xp??
robc
Olivier_G
robc
There is a post from me somewhere on the subject: as I said I've skipped b5 testing not to risk having to recreate all thumbs (due to the error in reordering the options), but in b4 folders are not cached automatically, only if you manually browse, as are video files by the way
The dialog wa responsive already in previous betas.
