resizable properties windows (ALT-ENTER)
loth
Post by loth »
hi folks,
the properties windows (ALT-ENTER, if viewing an image) should be resizable (or, at least bigger), so that the user can view/real ALL the EXIF information at once and not has to scroll up/down on every picture he wants to see the information.
cheers,
loth
GeorgD
Post by GeorgD »
+1 (yes, the preview pane can show a very high exif info, but this needs much more clicks than ALT+ENTER)
Moreover, CTRL+TAB does not rotate through tabs but behaves like normal TAB.
