When I use the convertion from NEF to TIF or JPG format, the size of the picture is reduced from 3872 x 2592 to 1952 x 1308. I didn't use any change function. I want to keep the full format of 3872 x 2592, but how?
Thank's for replies!
Bug in convert NEF to tif, jpg ? picture size gets smaller
Re: Bug in convert NEF to tif, jpg ? picture size gets small
option/Read/Camera RAW/Use high resolution is enabled?Volker wrote:When I use the convertion from NEF to TIF or JPG format, the size of the picture is reduced from 3872 x 2592 to 1952 x 1308. I didn't use any change function. I want to keep the full format of 3872 x 2592, but how?
mato
Hallo Pierre,xnview wrote:option/Read/Camera RAW/Use high resolution is enabled?Volker wrote:When I use the convertion from NEF to TIF or JPG format, the size of the picture is reduced from 3872 x 2592 to 1952 x 1308. I didn't use any change function. I want to keep the full format of 3872 x 2592, but how?
I must say I find the current behaviour of XnView inconsistent, at best.
When I double-click and open an image in XnView browser and then use "save as" the image is saved in original size. But when I right-click an image in XnView browser and choose batch conversion the image is saved in half size.
I couldn't understand it and believed it was a bug and only resolved it once I found your post above in this thread.
Still I believe the behaviour is inconsistent and simply not correct.
With regards,
Martin
kikobono
Hello.
Same problem here.
Has this been fixed?
Or is there any workaround for batch converting LOTS of raw in jpg?
Same problem here.
