Problems reading .big files
Post by Guest »
I'm trying to convert .big files to a more universal readable format. Bot Nconvertor isn't able to read the .big files I'm trying to convert ('could not be determined').
I've extracted to .big files from a IGN 1:25.000 CDROM (French maps producer). .big is originaly the Cartes Michelin format and is supported in Xnview. I suspect the by IGN used .big format is slightly changed for protection purposes... Has anyone any idea or even some experience how to convert this 'propierty' format?
Post by Guest »
I have same problem...
Atlas Routier Michelin Europe 2004 with this files:
/Raster/Data/eur_1000k_7.big
/Raster/Data/eur_1000k_75.big
/Raster/Data/eur_1000k_150.big
/Raster/Data/eur_1000k_300.big
XnView isn't able to read this .big files...
Anonymous wrote:I have same problem...
Is it possible to send me a sample?
Post by Guest »
I was send it... In June...
Anonymous wrote:I was send it... In June...
Never received it...
ChrisB
Post by ChrisB »
Hello!
Just wondering if this was ever fixed? I've just run into the same problem. I can provide a sample .big if needed, but they're pretty big (over 500MB). I think they contain a lot (!) of images.
ChrisB wrote:Hello!
I'll check this problem asap
nfafa
Post by nfafa »
Hello
Same problem when i try to convert .big michelin files.
Is there any news about it ?
Thanks
