Problem with IPTC
PierreDubarry
Problem with IPTC
Post by PierreDubarry »
HI,
I compare Xnview, Kalimage, Psp11, Photoshop CS2 for editing IPTC (using JPEG files).
When i write IPTC data with XnView, i don't see these data with others software.
When i write IPTC data, with Kalimage, i see these data with Psp11, Photoshop CS2, BUT NOT with Xnview.
What is the problem ?
Note : when i use an hexadecimal editor (or NotePad), in the file where IPTC data are written with Xnview, i can read data in ASCII form. For files where IPTC data are written with other software, Kalimage for example, IPTC data are not in ASCII, so no readable in text form.
Pierre
Troken
Post by Troken »
I've used IPTC in Photoshop and XnView and have not encountered the problem. :?
PierreDubarry
Strange,
why god for you and not for me.
... :evil:
Re: Problem with IPTC
PierreDubarry wrote:HI,
Pierre
Perhaps IPTC are saved in XMP, could you send me a sample, please?
PierreDubarry
IPTC
Exuce me, i think i have done bad test.
For example, i don't have see options on JPEG format for meta-data EXIF and IPTC !
I just done another test : i have made pictures with IPTC data with :
- ACDSEE 9
- KALIMAGES 2.1.3
- PHOTOSHOP CS2
- PAINT SHOP PRO XI
- XNVIEW 1.82.4
All IPTC data written with each tool are readable by others.
The only problem is the choice done by each tool : IPTC Data set selection is note the same in each tool.
I have done a web page with my pictures test :
http://dubarry.pierre.free.fr/iptc/
So Xnview works fine for IPTC, with more data than PSP11, but less than others.
A little question : when i save IPTC data, i think that picture part is all modified ; with JOEG copression it is bad for the picture. It could be better modify only meta-data if picture itself is not modified.
Thanks for your work.
Pierre
raul
writing iptc
Post by raul »
Hi from Spain:
I have a problem writing IPTC data and I thank to write here in this topic.
When I write IPTC keywords in thumbails mode data is saved.
However, when I write keywords in a only tab for that image, and I save changes, data isn't written. And all the keywords of this image are deleted.
My version is 1.82.4.
Thank you very much for your attention.
Re: writing iptc
raul wrote:Hi from Spain:
Which IPTC settings do you have for writing?
raul
Re: writing iptc
Post by raul »
Where can I see that, please?
Re: writing iptc
On the bottom of the dialog
raul
Post by raul »
ok I see.
It is strange..
A few minutes before I was writing IPTC data and the settings were visible, but now they are hidden.
The only marked option is the second (merge with existent...). And the only visible option is the first (keep atributes..).
raul
Post by raul »
this occurr:
when only one image is editing iptc data, the settings are hidden (only the first is visible).
and when more than one image is selected and editing iptc data, the settings are visible and modifiable.
GeorgD
Re: IPTC
Post by GeorgD »
PierreDubarry wrote:A little question : when i save IPTC data, i think that picture part is all modified ; with JOEG copression it is bad for the picture. It could be better modify only meta-data if picture itself is not modified.
See http://newsgroup.xnview.com/viewtopic.php?p=39709#39709 for this
