Cache configuration : crash
ug44
Post by ug44 »
Action is :
>Tools
>Options
>Thumbnails
>Cache Crash, Windows ask for sending a report ...
UG
Olivier_G
Post by Olivier_G »
I don't get the crash.
(On XP-SP2 +I deleted my previous versions INI and DB)
Olivier
ug44
Post by ug44 »
Also XP + SP2
The new beta 1.92 was copied from the .zip downloaded file in a new folder (not windows installation)
the old version remains on another folder.
UG
ckit
Post by ckit »
I cannot reproduce this bug.
Try deleting everything in "C:\Program Files\XnView\cache" and then test again.
ug44
Post by ug44 »
This solved this issue.
Thanks
marsh
Post by marsh »
ug44 wrote:This solved this issue.
Thanks
Great. I use multiple versions simultaneously, and have seen a crash likely caused by this experimentation. Please start new topic if you think you find something new and unique to this version.
