b1: crash if selecting .txt file for multi-page PDF
andreasm82
Post by andreasm82 »
I didn't see that there was a .txt file in my folder from which I selected some .jpg files to create a PDF file with the great multi-page feature.
As I want to start creating the PDF, xnview crashed.
BTW: Would be nice if I could add .txt files as text in the PDF file.
My private (german) page www.energie-bewusstsein.de
Re: b1: crash if selecting .txt file for multi-page PDF
andreasm82 wrote:I didn't see that there was a .txt file in my folder from which I selected some .jpg files to create a PDF file with the great multi-page feature.
Strange, i can't reproduce this bug. Do you have always the crash?
Olivier_G
Post by Olivier_G »
I confirm the bug: select 1 text file, then use Menu>Create>Multi-Page file and save as PDF.
=> Message "Format of the File <> could not be determined" => Crash (in PDF only).
There should be an automatic removal of non-displayable files by XnView without Crash (and can't text files be exported as text or image?)
Olivier
Olivier_G
Post by Olivier_G »
Olivier_G wrote:=> Message "Format of the File <> could not be determined" => Crash (in PDF only).
There is no crash anymore with Beta2...
...but isn't it possible to have a better handling of non-usable files while creating those PDF?
(ie: checking files beforehand, displaying a single alert message if there are many problematic files and asking to proceed (or not) with other good files)
-> Moved to 'Feedback' for this last part.
Olivier
Currently not, or use a 2 pass. Check first all files, and then create the PDF. But a little slower for some format...
Olivier_G
Post by Olivier_G »
xnview wrote:Currently not, or use a 2 pass. Check first all files, and then create the PDF. But a little slower for some format...
True. But I think the most important for those tools is to work correctly (before looking for speed/efficiency). It should also solve the issue raised in this topic, right?
Olivier
Olivier_G
Post by Olivier_G »
In beta 3, non-usable files are discarded before creating the multipage document. That's fine with me and solves the original bug -> closed.
Olivier
