When you use the Add folder button in Options|Thumbnails|Cache, when thumbnailing has terminated the dialog with the progressbar and Cancel button doesn't close, so you cannot see the process has ended unless you check CPU use with task manager and see that XnView is doing nothing.
This has happened both when adding a large set of folders and subfolders and a single folder containing just 4 image files and nothing else. I didn't use it much, but it seems to me that in Alpha this problem didn't occur.
B1: Cache|Add folder not closing
Right. Olivier_G won the race though and already posted it.
http://newsgroup.xnview.com/viewtopic.php?t=10621
