B1: Favourites make program hang
Danny
Post by Danny »
If you have bookmarked a folder from a remote PC as a favourite, which isn't currently connected to your network, the program gets stuck for about 10-20 seconds.
IMO Xnview shouldn't try to access favourites until i've clicked on one.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Danny
Post by Danny »
Fixed for the favourites pane but not for the favourites drop down menu in the toolbar. It doesn't hang as long anymore though.
Danny wrote:Fixed for the favourites pane but not for the favourites drop down menu in the toolbar. It doesn't hang as long anymore though.
You have a problem with favorites menu??
Danny
Post by Danny »
Yes. The program still hangs for a while, if you open up the favourites menu with a (currently) non-existing LAN-link in there.
Danny wrote:Yes. The program still hangs for a while, if you open up the favourites menu with a (currently) non-existing LAN-link in there.
Looks as this problem is still not fixed. -> New/Open
Danny
Post by Danny »
While the favourites pane had already been fixed, it now gets stuck again the first time you switch to it. After that it doesn't do it anymore.
The favourites drop-down menu never hangs now, though.
So, if you could revert any changes to the favourites pane since the last version, everything should be perfect i guess.
Danny wrote:While the favourites pane had already been fixed, it now gets stuck again the first time you switch to it. After that it doesn't do it anymore.
If you have some favorites of network drive, xnview try to access it???
Your favorite is something like "\\server\..." ??
Danny
Post by Danny »
xnview wrote:If you have some favorites of network drive, xnview try to access it???
At least it seems like that, since it (now) gets stuck (again), if i open up the favourites pane. It didn't do it for the pane in Beta2 or 3 - can't remember.
I'm using an UNC path ( "\\server\..." ), yes.
I've checked, and UNC path are not accessed, please try again with beta5
Danny
Post by Danny »
xnview wrote:I've checked, and UNC path are not accessed, please try again with beta5
Appears to work as expected now. Thanks.
