XnView Requires Internet Access?
torrbo
Post by torrbo »
When I start XnView it trys to connect to "omtrxpix.rd.com". If I deny access, which I do, the program runs for a few minutes then hangs up. Is internet access required for the program to run properly?
Phil M.
From where ?
:) Hello !
• I never saw this…
• XnView should need an Internet access if you ask for the forum or its Web site via the Info menu… But this address seems to be a fake.
• Here, I've several versions installed, and none asks for the connection.
- I've a firewall which'ld indicate that immediately !
• Which version are you running ? And please, let's know from where you got it.
:mrgreen: Kind regards,
torrbo
Internet access
Post by torrbo »
Claude, thanks for responding.
I downloaded the latest version (1.82.4) from the XnView website.
My previous version (1.82.2) also acted the same way only with a different url
And today when I started the program My firewall again caught XnView wanting to connect to "www200absolutehome.com.
I captured the firewall message from my screen but I don't know how to insert it in the post.
Strange behavior?
Phil
Some malware…
—> torrbo
:) Hello !
• Since you have the same issue with a correct new version, my feeling is that there is some malware in your PC,
maybe not really a virus, but a spy or so.
- The second URL you quote here is also a fancy one…
• Anyway, this is not caused by XnView, I guess.
- You might run an up-to-date anti-virus, i.e. Avira-Antivir Classic (freeware), and also a spy-killer like Spybot or similar.
- Please, pay attention that these malwares set themselves often as “hidden files”, so it's good to display all files in Win.
- I would bet €1 (no more, though…) that these programmes'll find the culprit !
- Please, let's know the continuation, it's always useful !
- To show a capture here, you must upload the image into a directory of your Web-site (if you have any), or else use an image-host like many do.
- Personally, I use my Web-sites, because the images are not deleted after a certain delay …
- On the board, use the marker [ img ]URL_of_the_image[ /img ] it's available on the message editor
(I added spaces inside here, but they don't exist normally)
:mrgreen: KR
marsh
Post by marsh »
This doesn't sound like an Xnview related issue.
--->General Support
