xnview.ini issue
Dreamer
xnview.ini issue
Post by Dreamer »
xnview.ini file is included in every beta version. It should not be included in the final version, perhaps also in RC versions, it's quite danger, all settings might be lost, if users don't have a backup.
Dreamer
ckit
Post by ckit »
I agree, this has annoyed me right from alpha 1.
Generated…
:) Hi !
• I agree too, XvView must generate it's if absent (that's not the case here for me currently…)
:mrgreen: KR
Dreamer
Re: Generated…
Post by Dreamer »
Clo wrote:...XvView must generate it's if absent (that's not the case here for me currently…)
Check your "user" folder:
C:\Documents and Settings\<user>\Application Data\XnView (Win XP)
Dreamer
ckit
Post by ckit »
Yea, I started using <user> as of beta 1.
Koogle
Post by Koogle »
would be nice if xnview just upgraded your ini, and kept your user settings.
Last beta update I had to use a file compare and manually edited the new .ini file just so that I wouldn't have to go through the options screen trying to pick all same settings, and colour styles.
Re: xnview.ini issue
Dreamer wrote:xnview.ini file is included in every beta version. It should not be included in the final version, perhaps also in RC versions, it's quite danger, all settings might be lost, if users don't have a backup.
In the final release, xnview.ini will not be added
Drahken
Post by Drahken »
On the other hand, keeping your old ini file with a new installation can cause bugs. See what happened to me in THIS THREAD . It'd be great if you could keep your old ini file without generating bugs, but.....
marsh
Post by marsh »
Beta.zip's .ini forces use of program folder. If you keep a copy of it, you may not need to look around as much in the user folders.
