Properties: Additional info for video files
I'm placing this request in the name of Karlo (who speaks little English, only):
In the properties pane many attributes are listed (File name, Description, File size, ...). For video clips, one can see length, width, height, Frames. I'd like to see additional info:
- Frames per second
- Video compression
Note:
The above attributes can be seen in Properties > Advanced of MS Windows Explorer.
XnView 1.90 <x>
ckit
Post by ckit »
I highly support this but it should be postponed for 1.91 or 2.0.
Re: B3: Properties: Additional info for video files
helmut wrote:I'm placing this request in the name of Karlo (who speaks little English, only):
- Frames per second
- Video compression
Note:
Yes, but currently i can't retrieve easily these info...
foxyshadis
Post by foxyshadis »
I'm not sure if there might be problems with the licenses, but this tool can easily determine basic information on all common video formats, and comes in a dll version:
http://mediainfo.sourceforge.net/en
I know the author answers quickly if you need to discuss using his tool, at some point.
Dreamer
Post by Dreamer »
I think the current info is sufficient for now, since it cannot be easily implemented, there are more important things to do* and Pierre is quite busy.
* for example, such a basic option as zoom doesn't work at all in xnview, for videos.
Dreamer
foxyshadis wrote:I'm not sure if there might be problems with the licenses, but this tool can easily determine basic information on all common video formats, and comes in a dll version:
Seems to be a great library, but for another release :-)
