[*] to reset zoom to 100% doesn't work in view or fullscreen mode anymore
and do you think it would be possible to add an option to use [shift] as a [ctrl] key when using the mousewheel to zoom in and out.. maybe allow the user to have [ctrl], [shift] etc user defined so they can set what those keys do when they use the mousewheel with one of those keys held down?
and last thing maybe you could add hotkey display/editor into the options panel so people can see what hotkeys can be used.. maybe at a later time allow it the hotkeys to be changed in the options too
XnView 1.90
